PF states limit reached
Добавлено: 04 мар 2015, 15:43
Код: Выделить всё
[zone: pf states] PF states limit reachedФорум сообщества системных администраторов и просто людей, которым не безразличен их компьютер.
https://pkgz.sysadmins.ws/
Код: Выделить всё
[zone: pf states] PF states limit reachedКод: Выделить всё
pfctl -sm
pfctl -si
netstat -m
sysctl -a | grep kern.ipc.nmbclustersКод: Выделить всё
states hard limit 10000
src-nodes hard limit 10000
frags hard limit 5000
table-entries hard limit 200000
Код: Выделить всё
Status: Enabled for 0 days 23:08:39 Debug: Urgent
State Table Total Rate
current entries 5759
searches 80402009 965.0/s
inserts 3655334 43.9/s
removals 3649575 43.8/s
Counters
match 13423899 161.1/s
bad-offset 0 0.0/s
fragment 0 0.0/s
short 0 0.0/s
normalize 0 0.0/s
memory 9661753 116.0/s
bad-timestamp 0 0.0/s
congestion 0 0.0/s
ip-option 104 0.0/s
proto-cksum 0 0.0/s
state-mismatch 118 0.0/s
state-insert 779 0.0/s
state-limit 0 0.0/s
src-limit 0 0.0/s
synproxy 0 0.0/s
Код: Выделить всё
259/1496/1755 mbufs in use (current/cache/total)
257/629/886/26368 mbuf clusters in use (current/cache/total/max)
257/618 mbuf+clusters out of packet secondary zone in use (current/cache)
0/91/91/13184 4k (page size) jumbo clusters in use (current/cache/total/max)
0/0/0/3906 9k jumbo clusters in use (current/cache/total/max)
0/0/0/2197 16k jumbo clusters in use (current/cache/total/max)
578K/1996K/2574K bytes allocated to network (current/cache/total)
0/0/0 requests for mbufs denied (mbufs/clusters/mbuf+clusters)
0/0/0 requests for mbufs delayed (mbufs/clusters/mbuf+clusters)
0/0/0 requests for jumbo clusters delayed (4k/9k/16k)
0/0/0 requests for jumbo clusters denied (4k/9k/16k)
0/61/6656 sfbufs in use (current/peak/max)
0 requests for sfbufs denied
0 requests for sfbufs delayed
18384 requests for I/O initiated by sendfileКод: Выделить всё
kern.ipc.nmbclusters: 26368kotig писал(а):257/629/886/26368 mbuf clusters in use (current/cache/total/max)
Попробуй увеличитьkotig писал(а):kern.ipc.nmbclusters: 26368
Код: Выделить всё
sysctl kern.ipc.nmbclusters=4073888Код: Выделить всё
kern.ipc.nmbclusters: 4073888что еще где куда смотреть?[zone: pf states] PF states limit reached
