Померла флешка
Добавлено: 12 май 2010, 19:34
Форум сообщества системных администраторов и просто людей, которым не безразличен их компьютер.
https://pkgz.sysadmins.ws/
Raven писал(а):Такими весчами я обычно занимаюсь под виндами.
Код: Выделить всё
fdisk -lКод: Выделить всё
dmesgКод: Выделить всё
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.30-std-def-alt15 (builder@apiary.orion.altlinux.org) (gcc version 4.3.2 20081105 (ALT Linux 4.3.2-alt13) (GCC) ) #1 SMP Mon Dec 14 08:45:48 UTC 2009
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] NSC Geode by NSC
[ 0.000000] Cyrix CyrixInstead
[ 0.000000] Centaur CentaurHauls
[ 0.000000] Transmeta GenuineTMx86
[ 0.000000] Transmeta TransmetaCPU
[ 0.000000] UMC UMC UMC UMC
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000002fffc000 (usable)
[ 0.000000] BIOS-e820: 000000002fffc000 - 000000002ffff000 (ACPI data)
[ 0.000000] BIOS-e820: 000000002ffff000 - 0000000030000000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
[ 0.000000] DMI 2.3 present.
[ 0.000000] last_pfn = 0x2fffc max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-C7FFF write-protect
[ 0.000000] C8000-EFFFF uncachable
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FE0000000 write-back
[ 0.000000] 1 base 020000000 mask FF0000000 write-back
[ 0.000000] 2 base 100000000 mask F00000000 write-back
[ 0.000000] 3 base 200000000 mask E00000000 write-back
[ 0.000000] 4 base 400000000 mask C00000000 write-back
[ 0.000000] 5 base 800000000 mask 800000000 write-back
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820 update range: 0000000030000000 - 0000000100000000 (usable) ==> (reserved)
[ 0.000000] e820 update range: 0000000000002000 - 0000000000006000 (usable) ==> (reserved)
[ 0.000000] Scanning 1 areas for low memory corruption
[ 0.000000] modified physical RAM map:
[ 0.000000] modified: 0000000000000000 - 0000000000002000 (usable)
[ 0.000000] modified: 0000000000002000 - 0000000000006000 (reserved)
[ 0.000000] modified: 0000000000006000 - 000000000009fc00 (usable)
[ 0.000000] modified: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] modified: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] modified: 0000000000100000 - 000000002fffc000 (usable)
[ 0.000000] modified: 000000002fffc000 - 000000002ffff000 (ACPI data)
[ 0.000000] modified: 000000002ffff000 - 0000000030000000 (ACPI NVS)
[ 0.000000] modified: 00000000fec00000 - 00000000fec01000 (reserved)
[ 0.000000] modified: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] modified: 00000000ffff0000 - 0000000100000000 (reserved)
[ 0.000000] init_memory_mapping: 0000000000000000-000000002fffc000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 002fc00000 page 2M
[ 0.000000] 002fc00000 - 002fffc000 page 4k
[ 0.000000] kernel direct mapping tables up to 2fffc000 @ 7000-c000
[ 0.000000] RAMDISK: 00e4a000 - 00eff1c7
[ 0.000000] ACPI: RSDP 000f51e0 00014 (v00 ASUS )
[ 0.000000] ACPI: RSDT 2fffc000 00030 (v01 ASUS P4G8X 42302E31 MSFT 31313031)
[ 0.000000] ACPI: FACP 2fffc0c0 00074 (v01 ASUS P4G8X 42302E31 MSFT 31313031)
[ 0.000000] ACPI: DSDT 2fffc134 027F5 (v01 ASUS P4G8X 00001000 MSFT 0100000B)
[ 0.000000] ACPI: FACS 2ffff000 00040
[ 0.000000] ACPI: BOOT 2fffc030 00028 (v01 ASUS P4G8X 42302E31 MSFT 31313031)
[ 0.000000] ACPI: APIC 2fffc058 0005A (v01 ASUS P4G8X 42302E31 MSFT 31313031)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 0MB HIGHMEM available.
[ 0.000000] 767MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 2fffc000
[ 0.000000] low ram: 0 - 2fffc000
[ 0.000000] node 0 low ram: 00000000 - 2fffc000
[ 0.000000] node 0 bootmap 00008000 - 0000e000
[ 0.000000] (9 early reservations) ==> bootmem [0000000000 - 002fffc000]
[ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000]
[ 0.000000] #1 [0000001000 - 0000002000] EX TRAMPOLINE ==> [0000001000 - 0000002000]
[ 0.000000] #2 [0000006000 - 0000007000] TRAMPOLINE ==> [0000006000 - 0000007000]
[ 0.000000] #3 [0000200000 - 0000744168] TEXT DATA BSS ==> [0000200000 - 0000744168]
[ 0.000000] #4 [0000e4a000 - 0000eff1c7] RAMDISK ==> [0000e4a000 - 0000eff1c7]
[ 0.000000] #5 [000009fc00 - 0000100000] BIOS reserved ==> [000009fc00 - 0000100000]
[ 0.000000] #6 [0000745000 - 0000748134] BRK ==> [0000745000 - 0000748134]
[ 0.000000] #7 [0000007000 - 0000008000] PGTABLE ==> [0000007000 - 0000008000]
[ 0.000000] #8 [0000008000 - 000000e000] BOOTMAP ==> [0000008000 - 000000e000]
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000000 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x0002fffc
[ 0.000000] HighMem 0x0002fffc -> 0x0002fffc
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[3] active PFN ranges
[ 0.000000] 0: 0x00000000 -> 0x00000002
[ 0.000000] 0: 0x00000006 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0002fffc
[ 0.000000] On node 0 totalpages: 196503
[ 0.000000] free_area_init_node: node 0, pgdat c0621fe0, node_mem_map c1000000
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3963 pages, LIFO batch:0
[ 0.000000] Normal zone: 1504 pages used for memmap
[ 0.000000] Normal zone: 191004 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0xe408
[ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl edge)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 22 low level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] SMP: Allowing 1 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 24
[ 0.000000] PM: Registered nosave memory: 0000000000002000 - 0000000000006000
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000
[ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at 40000000 (gap: 30000000:cec00000)
[ 0.000000] NR_CPUS:32 nr_cpumask_bits:32 nr_cpu_ids:1 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 11 pages at c1604000, static data 21820 bytes
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 194967
[ 0.000000] Kernel command line: auto BOOT_IMAGE=ALTLinux ro root=UUID=8c694252-357b-4ff9-89e1-91b966e08a04 resume=/dev/disk/by-uuid/d3695a22-7e3e-41a3-9ba6-09d6cf12ddb9 panic=30 splash=silent
[ 0.000000] bootsplash: silent mode.
[ 0.000000] Enabling fast FPU save and restore... done.
[ 0.000000] Enabling unmasked SIMD FPU exception support... done.
[ 0.000000] Initializing CPU#0
[ 0.000000] Experimental hierarchical RCU implementation.
[ 0.000000] Experimental hierarchical RCU init done.
[ 0.000000] NR_IRQS:2304 nr_irqs:256
[ 0.000000] PID hash table entries: 4096 (order: 12, 16384 bytes)
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 2214.321 MHz processor.
[ 0.004000] Console: colour dummy device 80x25
[ 0.004000] console [tty0] enabled
[ 0.004000] ram_console: buffer (null), invalid size 0, datasize 4294967284
[ 0.004000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.004000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.004000] allocated 3932080 bytes of page_cgroup
[ 0.004000] please try cgroup_disable=memory option if you don't want
[ 0.004000] Initializing HighMem for node 0 (00000000:00000000)
[ 0.004000] Memory: 768844k/786416k available (2862k kernel code, 17008k reserved, 1415k data, 460k init, 0k highmem)
[ 0.004000] virtual kernel memory layout:
[ 0.004000] fixmap : 0xffe16000 - 0xfffff000 (1956 kB)
[ 0.004000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.004000] vmalloc : 0xf07fc000 - 0xff7fe000 ( 240 MB)
[ 0.004000] lowmem : 0xc0000000 - 0xefffc000 ( 767 MB)
[ 0.004000] .init : 0xc0635000 - 0xc06a8000 ( 460 kB)
[ 0.004000] .data : 0xc04cb87d - 0xc062d828 (1415 kB)
[ 0.004000] .text : 0xc0200000 - 0xc04cb87d (2862 kB)
[ 0.004000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.004017] Calibrating delay loop (skipped), value calculated using timer frequency.. 4428.64 BogoMIPS (lpj=8857284)
[ 0.004109] Security Framework initialized
[ 0.004128] SELinux: Disabled at boot.
[ 0.004163] Mount-cache hash table entries: 512
[ 0.004428] Initializing cgroup subsys ns
[ 0.004447] Initializing cgroup subsys cpuacct
[ 0.004456] Initializing cgroup subsys memory
[ 0.004470] Initializing cgroup subsys devices
[ 0.004479] Initializing cgroup subsys freezer
[ 0.004485] Initializing cgroup subsys net_cls
[ 0.004541] CPU: Trace cache: 12K uops, L1 D cache: 8K
[ 0.004553] CPU: L2 cache: 128K
[ 0.004560] CPU: Hyper-Threading is disabled
[ 0.004568] Intel machine check architecture supported.
[ 0.004580] Intel machine check reporting enabled on CPU#0.
[ 0.004589] CPU0: Intel P4/Xeon Extended MCE MSRs (12) available
[ 0.004599] CPU0: Thermal monitoring enabled
[ 0.004626] Checking 'hlt' instruction... OK.
[ 0.020777] SMP alternatives: switching to UP code
[ 0.029251] Freeing SMP alternatives: 19k freed
[ 0.029301] ACPI: Core revision 20090320
[ 0.037034] alloc irq_desc for 22 on cpu 0 node 0
[ 0.037038] alloc kstat_irqs on cpu 0 node 0
[ 0.037174] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.076887] CPU0: Intel(R) Celeron(R) CPU 1.80GHz stepping 09
[ 0.080001] Brought up 1 CPUs
[ 0.080001] Total of 1 processors activated (4428.64 BogoMIPS).
[ 0.080001] CPU0 attaching NULL sched-domain.
[ 0.080001] net_namespace: 1088 bytes
[ 0.080001] regulator: core version 0.5
[ 0.080001] NET: Registered protocol family 16
[ 0.080001] EISA bus registered
[ 0.080001] ACPI: bus type pci registered
[ 0.082337] PCI: PCI BIOS revision 2.10 entry at 0xf1db0, last bus=2
[ 0.082351] PCI: Using configuration type 1 for base access
[ 0.090160] bio: create slab <bio-0> at 0
[ 0.091319] ACPI: EC: Look up EC in DSDT
[ 0.101311] ACPI: Interpreter enabled
[ 0.101336] ACPI: (supports S0 S1 S4 S5)
[ 0.101383] ACPI: Using IOAPIC for interrupt routing
[ 0.119131] ACPI: No dock devices found.
[ 0.119176] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.119427] pci 0000:00:00.0: reg 10 32bit mmio: [0xf0000000-0xf7ffffff]
[ 0.119488] pci 0000:00:01.0: reg 10 32bit mmio: [0xe8000000-0xefffffff]
[ 0.119575] pci 0000:00:1d.0: reg 20 io port: [0xd800-0xd81f]
[ 0.119635] pci 0000:00:1d.1: reg 20 io port: [0xd400-0xd41f]
[ 0.119693] pci 0000:00:1d.2: reg 20 io port: [0xd000-0xd01f]
[ 0.119758] pci 0000:00:1d.7: reg 10 32bit mmio: [0xdd800000-0xdd8003ff]
[ 0.119818] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.119833] pci 0000:00:1d.7: PME# disabled
[ 0.119894] * The chipset may have PM-Timer Bug. Due to workarounds for a bug,
[ 0.119896] * this clock source is slow. If you are sure your timer does not have
[ 0.119898] * this bug, please use "acpi_pm_good" to disable the workaround
[ 0.120091] pci 0000:00:1f.0: Enabled i801 SMBus device
[ 0.120107] pci 0000:00:1f.0: quirk: region e400-e47f claimed by ICH4 ACPI/GPIO/TCO
[ 0.120117] pci 0000:00:1f.0: quirk: region ec00-ec3f claimed by ICH4 GPIO
[ 0.120159] pci 0000:00:1f.1: reg 10 io port: [0x00-0x07]
[ 0.120168] pci 0000:00:1f.1: reg 14 io port: [0x00-0x03]
[ 0.120176] pci 0000:00:1f.1: reg 18 io port: [0x00-0x07]
[ 0.120184] pci 0000:00:1f.1: reg 1c io port: [0x00-0x03]
[ 0.120192] pci 0000:00:1f.1: reg 20 io port: [0xf000-0xf00f]
[ 0.120200] pci 0000:00:1f.1: reg 24 32bit mmio: [0x000000-0x0003ff]
[ 0.120256] pci 0000:00:1f.3: reg 20 io port: [0xe800-0xe81f]
[ 0.120322] pci 0000:01:00.0: reg 10 32bit mmio: [0xde000000-0xdeffffff]
[ 0.120330] pci 0000:01:00.0: reg 14 32bit mmio: [0xe0000000-0xe7ffffff]
[ 0.120351] pci 0000:01:00.0: reg 30 32bit mmio: [0xdffe0000-0xdfffffff]
[ 0.120411] pci 0000:00:01.0: bridge 32bit mmio: [0xde000000-0xdfdfffff]
[ 0.120417] pci 0000:00:01.0: bridge 32bit mmio pref: [0xdff00000-0xe7ffffff]
[ 0.120461] pci 0000:02:04.0: reg 10 io port: [0xb800-0xb807]
[ 0.120470] pci 0000:02:04.0: reg 14 io port: [0xb400-0xb403]
[ 0.120477] pci 0000:02:04.0: reg 18 io port: [0xb000-0xb007]
[ 0.120485] pci 0000:02:04.0: reg 1c io port: [0xa800-0xa803]
[ 0.120493] pci 0000:02:04.0: reg 20 io port: [0xa400-0xa40f]
[ 0.120501] pci 0000:02:04.0: reg 24 32bit mmio: [0xdd000000-0xdd0001ff]
[ 0.120509] pci 0000:02:04.0: reg 30 32bit mmio: [0xdfe80000-0xdfefffff]
[ 0.120529] pci 0000:02:04.0: supports D1 D2
[ 0.120591] pci 0000:02:05.0: reg 10 64bit mmio: [0xdc800000-0xdc80ffff]
[ 0.120619] pci 0000:02:05.0: reg 30 32bit mmio: [0xdfe70000-0xdfe7ffff]
[ 0.120650] pci 0000:02:05.0: PME# supported from D3hot D3cold
[ 0.120661] pci 0000:02:05.0: PME# disabled
[ 0.120708] pci 0000:00:1e.0: transparent bridge
[ 0.120718] pci 0000:00:1e.0: bridge io port: [0xa000-0xbfff]
[ 0.120724] pci 0000:00:1e.0: bridge 32bit mmio: [0xdc800000-0xdd7fffff]
[ 0.120730] pci 0000:00:1e.0: bridge 32bit mmio pref: [0xdfe00000-0xdfefffff]
[ 0.120744] pci_bus 0000:00: on NUMA node 0
[ 0.120763] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.120901] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI1._PRT]
[ 0.120984] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI2._PRT]
[ 0.125425] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12 14 15)
[ 0.125628] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
[ 0.125852] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 6 7 9 10 11 12 14 15)
[ 0.126066] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 *9 10 11 12 14 15)
[ 0.126259] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
[ 0.126475] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 *9 10 11 12 14 15)
[ 0.126665] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
[ 0.126860] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
[ 0.128645] PCI: Using ACPI for IRQ routing
[ 0.129191] NetLabel: Initializing
[ 0.129204] NetLabel: domain hash size = 128
[ 0.129209] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.129241] NetLabel: unlabeled traffic allowed by default
[ 0.129440] pnp: PnP ACPI init
[ 0.129481] ACPI: bus type pnp registered
[ 0.141575] pnp: PnP ACPI: found 17 devices
[ 0.141590] ACPI: ACPI bus type pnp unregistered
[ 0.141600] PnPBIOS: Disabled by ACPI PNP
[ 0.141629] system 00:00: iomem range 0x0-0x9ffff could not be reserved
[ 0.141638] system 00:00: iomem range 0xf0000-0xfffff could not be reserved
[ 0.141646] system 00:00: iomem range 0x100000-0x2fffffff could not be reserved
[ 0.141655] system 00:00: iomem range 0xfec00000-0xfec000ff could not be reserved
[ 0.141663] system 00:00: iomem range 0xfee00000-0xfee00fff has been reserved
[ 0.141682] system 00:02: ioport range 0xe400-0xe47f has been reserved
[ 0.141689] system 00:02: ioport range 0xe800-0xe81f has been reserved
[ 0.141697] system 00:02: ioport range 0xec00-0xec3f has been reserved
[ 0.141704] system 00:02: ioport range 0x4d6-0x4d6 has been reserved
[ 0.141712] system 00:02: iomem range 0xfff80000-0xffffffff could not be reserved
[ 0.141720] system 00:02: iomem range 0xffb80000-0xffbfffff has been reserved
[ 0.141734] system 00:03: ioport range 0x4d0-0x4d1 has been reserved
[ 0.141757] system 00:10: ioport range 0x3f0-0x3f1 has been reserved
[ 0.178117] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
[ 0.178131] pci 0000:00:01.0: IO window: disabled
[ 0.178139] pci 0000:00:01.0: MEM window: 0xde000000-0xdfdfffff
[ 0.178148] pci 0000:00:01.0: PREFETCH window: 0x000000dff00000-0x000000e7ffffff
[ 0.178162] pci 0000:00:1e.0: PCI bridge, secondary bus 0000:02
[ 0.178170] pci 0000:00:1e.0: IO window: 0xa000-0xbfff
[ 0.178179] pci 0000:00:1e.0: MEM window: 0xdc800000-0xdd7fffff
[ 0.178188] pci 0000:00:1e.0: PREFETCH window: 0x000000dfe00000-0x000000dfefffff
[ 0.178211] pci 0000:00:01.0: setting latency timer to 64
[ 0.178223] pci 0000:00:1e.0: setting latency timer to 64
[ 0.178231] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.178235] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
[ 0.178239] pci_bus 0000:01: resource 1 mem: [0xde000000-0xdfdfffff]
[ 0.178243] pci_bus 0000:01: resource 2 pref mem [0xdff00000-0xe7ffffff]
[ 0.178248] pci_bus 0000:02: resource 0 io: [0xa000-0xbfff]
[ 0.178252] pci_bus 0000:02: resource 1 mem: [0xdc800000-0xdd7fffff]
[ 0.178256] pci_bus 0000:02: resource 2 pref mem [0xdfe00000-0xdfefffff]
[ 0.178260] pci_bus 0000:02: resource 3 io: [0x00-0xffff]
[ 0.178263] pci_bus 0000:02: resource 4 mem: [0x000000-0xffffffff]
[ 0.178370] NET: Registered protocol family 2
[ 0.178553] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.179261] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.181185] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.182175] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.182192] TCP reno registered
[ 0.182448] NET: Registered protocol family 1
[ 0.182583] Trying to unpack rootfs image as initramfs...
[ 0.222233] Freeing initrd memory: 724k freed
[ 0.223986] Simple Boot Flag at 0x3a set to 0x1
[ 0.224959] Scanning for low memory corruption every 60 seconds
[ 0.225927] audit: initializing netlink socket (disabled)
[ 0.225961] type=2000 audit(1273772182.224:1): initialized
[ 0.233121] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.233331] VFS: Disk quotas dquot_6.5.2
[ 0.233413] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.233549] msgmni has been set to 1503
[ 0.234088] alg: No test for stdrng (krng)
[ 0.234360] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
[ 0.234379] io scheduler noop registered
[ 0.234385] io scheduler anticipatory registered
[ 0.234427] io scheduler cfq registered (default)
[ 0.234518] pci 0000:01:00.0: Boot video device
[ 0.235742] vesafb: framebuffer at 0xe0000000, mapped to 0xf0880000, using 3750k, total 131072k
[ 0.235761] vesafb: mode is 800x600x16, linelength=1600, pages=2
[ 0.235767] vesafb: protected mode interface info at c000:e2f0
[ 0.235773] vesafb: pmi: set display start = c00ce326, set palette = c00ce390
[ 0.235779] vesafb: pmi: ports = 3b4 3b5 3ba 3c0 3c1 3c4 3c5 3c6 3c7 3c8 3c9 3cc 3ce 3cf 3d0 3d1 3d2 3d3 3d4 3d5 3da
[ 0.235810] vesafb: scrolling: redraw
[ 0.235818] vesafb: Truecolor: size=0:5:6:5, shift=0:11:5:0
[ 0.236344] bootsplash 3.1.6-2004/03/31: looking for picture...
[ 0.252498] bootsplash: silentjpeg size 30735 bytes
[ 0.269277] bootsplash: ...found (800x600, 56202 bytes, v3).
[ 0.322236] Console: switching to colour frame buffer device 97x34
[ 0.393256] fb0: VESA VGA frame buffer device
[ 0.393851] isapnp: Scanning for PnP cards...
[ 0.679984] Switched to high resolution mode on CPU 0
[ 0.704106] isapnp: No Plug & Play device found
[ 0.962298] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.962974] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.963939] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 0.967206] 00:0a: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.968944] 00:0b: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 0.976850] brd: module loaded
[ 0.984257] input: Macintosh mouse button emulation as /devices/virtual/input/input0
[ 0.992244] Fixed MDIO Bus: probed
[ 0.999998] PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 1.010864] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.018451] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.027334] mice: PS/2 mouse device common for all mice
[ 1.035339] EISA: Probing bus 0 at eisa.0
[ 1.042883] cpuidle: using governor ladder
[ 1.050079] cpuidle: using governor menu
[ 1.058130] TCP bic registered
[ 1.065393] Using IPI No-Shortcut mode
[ 1.082338] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input1
[ 1.095543] registered taskstats version 1
[ 1.103050] Freeing unused kernel memory: 460k freed
[ 1.111066] Write protecting the kernel text: 2864k
[ 1.118283] Write protecting the kernel read-only data: 1220k
[ 1.125408] Executing init=/init
[ 2.414068] Uniform Multi-Platform E-IDE driver
[ 2.436851] piix 0000:00:1f.1: IDE controller (0x8086:0x24cb rev 0x02)
[ 2.443735] alloc irq_desc for 18 on cpu 0 node 0
[ 2.443743] alloc kstat_irqs on cpu 0 node 0
[ 2.443755] PIIX_IDE 0000:00:1f.1: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 2.450723] piix 0000:00:1f.1: not 100% native mode: will probe irqs later
[ 2.457665] ide0: BM-DMA at 0xf000-0xf007
[ 2.464611] ide1: BM-DMA at 0xf008-0xf00f
[ 2.471444] Probing IDE interface ide0...
[ 3.208163] hda: ATAPI DVD A DH20A3P, ATAPI CD/DVD-ROM drive
[ 3.884112] hda: host max PIO4 wanted PIO255(auto-tune) selected PIO4
[ 3.884454] hda: host side 80-wire cable detection failed, limiting max speed to UDMA33
[ 3.891518] hda: UDMA/33 mode selected
[ 3.899026] Probing IDE interface ide1...
[ 4.184165] hdc: WDC WD800BB-00JHA0, ATA DISK drive
[ 4.524035] hdd: MAXTOR STM3160215A, ATA DISK drive
[ 4.531287] hdc: host max PIO4 wanted PIO255(auto-tune) selected PIO4
[ 4.531369] hdc: host side 80-wire cable detection failed, limiting max speed to UDMA33
[ 4.538781] hdc: UDMA/33 mode selected
[ 4.546065] hdd: host max PIO4 wanted PIO255(auto-tune) selected PIO4
[ 4.546274] hdd: host side 80-wire cable detection failed, limiting max speed to UDMA33
[ 4.553656] hdd: UDMA/33 mode selected
[ 4.561088] ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
[ 4.581216] ide1 at 0x170-0x177,0x376 on irq 15
[ 4.669437] ide-gd driver 1.18
[ 4.676506] hdc: max request size: 128KiB
[ 4.700561] hdc: 156301488 sectors (80026 MB) w/2048KiB Cache, CHS=65535/16/63
[ 4.713309] ide_generic: please use "probe_mask=0x3f" module parameter for probing all legacy ISA IDE ports
[ 4.729226] hdc: cache flushes supported
[ 4.736993] hdc: hdc1
[ 4.749002] hdd: max request size: 512KiB
[ 4.799947] hdd: 312581808 sectors (160041 MB) w/2048KiB Cache, CHS=19457/255/63
[ 4.824306] hdd: cache flushes supported
[ 4.831804] hdd: hdd1 hdd4 < hdd5 hdd6 hdd7 >
[ 4.950393] SCSI subsystem initialized
[ 4.992635] Driver 'sd' needs updating - please use bus_type methods
[ 5.044401] libata version 3.00 loaded.
[ 5.094965] sata_sil 0000:02:04.0: version 2.4
[ 5.095040] alloc irq_desc for 21 on cpu 0 node 0
[ 5.095044] alloc kstat_irqs on cpu 0 node 0
[ 5.095058] sata_sil 0000:02:04.0: PCI INT A -> GSI 21 (level, low) -> IRQ 21
[ 5.116794] scsi0 : sata_sil
[ 5.126841] scsi1 : sata_sil
[ 5.134677] ata1: SATA max UDMA/100 mmio m512@0xdd000000 tf 0xdd000080 irq 21
[ 5.142627] ata2: SATA max UDMA/100 mmio m512@0xdd000000 tf 0xdd0000c0 irq 21
[ 5.472062] ata1: SATA link down (SStatus 0 SControl 310)
[ 5.796035] ata2: SATA link down (SStatus 0 SControl 310)
[ 7.497212] PM: Starting manual resume from disk
[ 7.561130] kjournald starting. Commit interval 5 seconds
[ 7.568763] EXT3-fs: mounted filesystem with writeback data mode.
[ 10.341291] Linux agpgart interface v0.103
[ 10.366511] agpgart-intel 0000:00:00.0: Intel E7205 Chipset
[ 10.373072] agpgart-intel 0000:00:00.0: AGP aperture is 128M @ 0xf0000000
[ 10.397279] ACPI: Invalid PBLK length [5]
[ 10.397367] processor ACPI_CPU:00: registered as cooling_device0
[ 10.439698] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 10.439711] ACPI: Power Button [PWRF]
[ 10.439815] input: Power Button as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input3
[ 10.439825] ACPI: Power Button [PWRB]
[ 10.580885] rtc_cmos 00:05: RTC can wake from S4
[ 10.581180] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[ 10.581219] rtc0: alarms up to one month, 242 bytes nvram
[ 10.613568] ide-cd driver 5.00
[ 10.616112] ide-cd: hda: ATAPI 12X DVD-ROM DVD-R/RAM CD-R/RW drive, 2048kB Cache
[ 10.616126] Uniform CD-ROM driver Revision: 3.20
[ 10.752384] input: PC Speaker as /devices/platform/pcspkr/input/input4
[ 10.822093] alloc irq_desc for 17 on cpu 0 node 0
[ 10.822099] alloc kstat_irqs on cpu 0 node 0
[ 10.822111] i801_smbus 0000:00:1f.3: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[ 10.878538] gameport: NS558 PnP Gameport is pnp00:0f/gameport0, io 0x200, speed 903kHz
[ 10.957371] tg3.c:v3.98 (February 25, 2009)
[ 10.957392] tg3 0000:02:05.0: enabling device (0014 -> 0016)
[ 10.957405] tg3 0000:02:05.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 10.969148] tg3 0000:02:05.0: PME# disabled
[ 10.999849] eth0: Tigon3 [partno(BCM95702A20) rev 1002] (PCI:33MHz:32-bit) MAC address 00:0c:6e:26:a8:02
[ 10.999857] eth0: attached PHY is 5703 (10/100/1000Base-T Ethernet) (WireSpeed[1])
[ 10.999861] eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] TSOcap[1]
[ 10.999865] eth0: dma_rwctrl[763f0000] dma_mask[64-bit]
[ 11.003248] Floppy drive(s): fd0 is 1.44M
[ 11.010614] parport_pc 00:09: reported by Plug and Play ACPI
[ 11.010675] parport0: PC-style at 0x378 (0x778), irq 7, dma 3 [PCSPP,TRISTATE,COMPAT,ECP,DMA]
[ 11.023847] FDC 0 is a post-1991 82077
[ 11.234176] usbcore: registered new interface driver usbfs
[ 11.234250] usbcore: registered new interface driver hub
[ 11.234365] usbcore: registered new device driver usb
[ 11.237163] uhci_hcd: USB Universal Host Controller Interface driver
[ 11.237256] alloc irq_desc for 16 on cpu 0 node 0
[ 11.237260] alloc kstat_irqs on cpu 0 node 0
[ 11.237271] uhci_hcd 0000:00:1d.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 11.237286] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 11.237292] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 11.237392] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 1
[ 11.237443] uhci_hcd 0000:00:1d.0: irq 16, io base 0x0000d800
[ 11.237529] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
[ 11.237534] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 11.237537] usb usb1: Product: UHCI Host Controller
[ 11.237540] usb usb1: Manufacturer: Linux 2.6.30-std-def-alt15 uhci_hcd
[ 11.237543] usb usb1: SerialNumber: 0000:00:1d.0
[ 11.237865] usb usb1: configuration #1 chosen from 1 choice
[ 11.237942] hub 1-0:1.0: USB hub found
[ 11.237968] hub 1-0:1.0: 2 ports detected
[ 11.238669] alloc irq_desc for 19 on cpu 0 node 0
[ 11.238675] alloc kstat_irqs on cpu 0 node 0
[ 11.238686] uhci_hcd 0000:00:1d.1: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[ 11.238700] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 11.238705] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 11.238779] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 2
[ 11.238827] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000d400
[ 11.238901] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 11.238907] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 11.238910] usb usb2: Product: UHCI Host Controller
[ 11.238913] usb usb2: Manufacturer: Linux 2.6.30-std-def-alt15 uhci_hcd
[ 11.238916] usb usb2: SerialNumber: 0000:00:1d.1
[ 11.239237] usb usb2: configuration #1 chosen from 1 choice
[ 11.239315] hub 2-0:1.0: USB hub found
[ 11.239339] hub 2-0:1.0: 2 ports detected
[ 11.239985] uhci_hcd 0000:00:1d.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 11.240038] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 11.240045] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 11.240138] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 3
[ 11.240187] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000d000
[ 11.240272] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 11.240277] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 11.240280] usb usb3: Product: UHCI Host Controller
[ 11.240283] usb usb3: Manufacturer: Linux 2.6.30-std-def-alt15 uhci_hcd
[ 11.240286] usb usb3: SerialNumber: 0000:00:1d.2
[ 11.240614] usb usb3: configuration #1 chosen from 1 choice
[ 11.240684] hub 3-0:1.0: USB hub found
[ 11.240716] hub 3-0:1.0: 2 ports detected
[ 11.246204] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 11.246210] Warning! ehci_hcd should always be loaded before uhci_hcd and ohci_hcd, not after
[ 11.246263] ehci_hcd 0000:00:1d.7: enabling device (0004 -> 0006)
[ 11.246277] alloc irq_desc for 23 on cpu 0 node 0
[ 11.246281] alloc kstat_irqs on cpu 0 node 0
[ 11.246292] ehci_hcd 0000:00:1d.7: PCI INT D -> GSI 23 (level, low) -> IRQ 23
[ 11.246342] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 11.246348] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 11.246431] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 4
[ 11.250354] ehci_hcd 0000:00:1d.7: debug port 1
[ 11.250363] ehci_hcd 0000:00:1d.7: cache line size of 128 is not supported
[ 11.250394] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xdd800000
[ 11.264187] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 11.264263] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[ 11.264268] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 11.264272] usb usb4: Product: EHCI Host Controller
[ 11.264275] usb usb4: Manufacturer: Linux 2.6.30-std-def-alt15 ehci_hcd
[ 11.264278] usb usb4: SerialNumber: 0000:00:1d.7
[ 11.264637] usb usb4: configuration #1 chosen from 1 choice
[ 11.264713] hub 4-0:1.0: USB hub found
[ 11.264736] hub 4-0:1.0: 6 ports detected
[ 11.352340] psmouse serio1: ID: 30 00 64
[ 11.688131] usb 4-6: new high speed USB device using ehci_hcd and address 3
[ 11.820455] usb 4-6: New USB device found, idVendor=1307, idProduct=0163
[ 11.820462] usb 4-6: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 11.820788] usb 4-6: configuration #1 chosen from 1 choice
[ 12.060162] usb 3-1: new full speed USB device using uhci_hcd and address 2
[ 12.258624] input: ImExPS/2 Generic Explorer Mouse as /devices/platform/i8042/serio1/input/input5
[ 12.292079] usb 3-1: New USB device found, idVendor=047f, idProduct=0ca1
[ 12.292087] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 12.292091] usb 3-1: Product: Plantronics Headset
[ 12.292095] usb 3-1: Manufacturer: Plantronics
[ 12.292098] usb 3-1: SerialNumber: 00100-0429034410003-V060000A
[ 12.292447] usb 3-1: configuration #1 chosen from 1 choice
[ 13.204594] ppdev: user-space parallel port driver
[ 13.663405] usbcore: registered new interface driver libusual
[ 13.683418] Initializing USB Mass Storage driver...
[ 13.683695] scsi2 : SCSI emulation for USB Mass Storage devices
[ 13.683951] usbcore: registered new interface driver usb-storage
[ 13.683960] USB Mass Storage support registered.
[ 13.694977] usb-storage: device found at 3
[ 13.694983] usb-storage: waiting for device to settle before scanning
[ 13.818751] usbcore: registered new interface driver hiddev
[ 13.824746] input: Plantronics Plantronics Headset as /devices/pci0000:00/0000:00:1d.2/usb3/3-1/3-1:1.3/input/input6
[ 13.825388] generic-usb 0003:047F:0CA1.0001: input,hidraw0: USB HID v1.00 Device [Plantronics Plantronics Headset] on usb-0000:00:1d.2-1/input3
[ 13.825431] usbcore: registered new interface driver usbhid
[ 13.825439] usbhid: v2.6:USB HID core driver
[ 13.952707] usbcore: registered new interface driver snd-usb-audio
[ 15.112082] Adding 1951856k swap on /dev/hdd5. Priority:-1 extents:1 across:1951856k
[ 15.504125] EXT3 FS on hdd6, internal journal
[ 18.775922] device-mapper: uevent: version 1.0.3
[ 18.778796] device-mapper: ioctl: 4.14.0-ioctl (2008-04-23) initialised: dm-devel@redhat.com
[ 19.894260] kjournald starting. Commit interval 5 seconds
[ 19.894532] EXT3 FS on hdd7, internal journal
[ 19.894543] EXT3-fs: mounted filesystem with writeback data mode.
[ 19.980806] fuse init (API version 7.12)
[ 24.928099] usb 4-6: reset high speed USB device using ehci_hcd and address 3
[ 28.372395] tg3 0000:02:05.0: firmware: requesting tigon/tg3_tso.bin
[ 28.417403] tg3 0000:02:05.0: PME# disabled
[ 30.265511] tg3: eth0: Link is up at 100 Mbps, full duplex.
[ 30.265517] tg3: eth0: Flow control is off for TX and off for RX.
[ 30.293843] NET: Registered protocol family 17
[ 35.172032] usb 4-6: reset high speed USB device using ehci_hcd and address 3
[ 51.416033] usb 4-6: reset high speed USB device using ehci_hcd and address 3
[ 51.664027] usb 4-6: reset high speed USB device using ehci_hcd and address 3
[ 61.908085] usb 4-6: reset high speed USB device using ehci_hcd and address 3
[ 62.040439] scsi 2:0:0:0: Device offlined - not ready after error recovery
[ 62.041332] usb-storage: device scan complete
[ 62.259364] Bluetooth: Core ver 2.15
[ 62.262429] NET: Registered protocol family 31
[ 62.262436] Bluetooth: HCI device and connection manager initialized
[ 62.262441] Bluetooth: HCI socket layer initialized
[ 62.280476] Bluetooth: L2CAP ver 2.13
[ 62.280481] Bluetooth: L2CAP socket layer initialized
[ 62.380397] Bluetooth: SCO (Voice Link) ver 0.6
[ 62.380403] Bluetooth: SCO socket layer initialized
[ 62.424856] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 62.424862] Bluetooth: BNEP filters: protocol multicast
[ 62.460995] Bridge firewalling registered
[ 65.682496] RPC: Registered udp transport module.
[ 65.682503] RPC: Registered tcp transport module.
[ 73.038827] nvidia: module license 'NVIDIA' taints kernel.
[ 73.038836] Disabling lock debugging due to kernel taint
[ 73.299558] nvidia 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 73.300144] NVRM: loading NVIDIA UNIX x86 Kernel Module 173.14.22 Sun Nov 8 20:26:31 PST 2009
[ 73.434374] agpgart-intel 0000:00:00.0: AGP 3.0 bridge
[ 73.434396] agpgart-intel 0000:00:00.0: putting AGP V3 device into 8x mode
[ 73.434429] nvidia 0000:01:00.0: putting AGP V3 device into 8x mode
[ 78.871343] QEMU Accelerator Module version 1.4.0, Copyright (c) 2005-2008 Fabrice Bellard
[ 78.871675] KQEMU installed, max_locked_mem=385104kB.
[ 79.125402] vboxdrv: Trying to deactivate the NMI watchdog permanently...
[ 79.125409] vboxdrv: Successfully done.
[ 79.125412] vboxdrv: Found 1 processor cores.
[ 79.125837] vboxdrv: TSC mode is 'synchronous', kernel timer mode is 'normal'.
[ 79.125842] vboxdrv: Successfully loaded version 3.0.10_OSE (interface 0x000e0001).
[ 79.817698] vboxNetAdpOpen returns 0
[ 149.145462] PPP generic driver version 2.4.2
[ 149.198967] HDLC line discipline: version $Revision: 4.8 $, maxframe=4096
[ 149.198973] N_HDLC line discipline registered.
[ 149.281830] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 151.756893] PPP BSD Compression module registered
[ 197.517860] IN=ppp0 OUT= MAC= SRC=77.235.22.30 DST=109.201.167.149 LEN=78 TOS=0x00 PREC=0x00 TTL=127 ID=11696 PROTO=UDP SPT=63884 DPT=137 LEN=58
[ 197.517934] IN=ppp0 OUT= MAC= SRC=77.235.22.30 DST=109.201.167.149 LEN=78 TOS=0x00 PREC=0x00 TTL=127 ID=11697 PROTO=UDP SPT=62386 DPT=137 LEN=58
[ 197.517990] IN=ppp0 OUT= MAC= SRC=77.235.22.30 DST=109.201.167.149 LEN=78 TOS=0x00 PREC=0x00 TTL=127 ID=11698 PROTO=UDP SPT=137 DPT=137 LEN=58
[ 199.015575] IN=ppp0 OUT= MAC= SRC=77.235.22.30 DST=109.201.167.149 LEN=78 TOS=0x00 PREC=0x00 TTL=127 ID=12311 PROTO=UDP SPT=63884 DPT=137 LEN=58
[ 199.015640] IN=ppp0 OUT= MAC= SRC=77.235.22.30 DST=109.201.167.149 LEN=78 TOS=0x00 PREC=0x00 TTL=127 ID=12312 PROTO=UDP SPT=62386 DPT=137 LEN=58
[ 199.015695] IN=ppp0 OUT= MAC= SRC=77.235.22.30 DST=109.201.167.149 LEN=78 TOS=0x00 PREC=0x00 TTL=127 ID=12313 PROTO=UDP SPT=137 DPT=137 LEN=58
[ 200.515465] IN=ppp0 OUT= MAC= SRC=77.235.22.30 DST=109.201.167.149 LEN=78 TOS=0x00 PREC=0x00 TTL=127 ID=12945 PROTO=UDP SPT=63884 DPT=137 LEN=58
[ 200.515529] IN=ppp0 OUT= MAC= SRC=77.235.22.30 DST=109.201.167.149 LEN=78 TOS=0x00 PREC=0x00 TTL=127 ID=12946 PROTO=UDP SPT=62386 DPT=137 LEN=58
[ 200.515585] IN=ppp0 OUT= MAC= SRC=77.235.22.30 DST=109.201.167.149 LEN=78 TOS=0x00 PREC=0x00 TTL=127 ID=12947 PROTO=UDP SPT=137 DPT=137 LEN=58
[ 257.542199] IN=ppp0 OUT= MAC= SRC=77.235.31.11 DST=109.201.167.149 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=3662 DF PROTO=TCP SPT=3998 DPT=37633 WINDOW=65535 RES=0x00 SYN URGP=0
[ 260.506081] IN=ppp0 OUT= MAC= SRC=77.235.31.11 DST=109.201.167.149 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=4413 DF PROTO=TCP SPT=3998 DPT=37633 WINDOW=65535 RES=0x00 SYN URGP=0
[ 266.441454] IN=ppp0 OUT= MAC= SRC=77.235.31.11 DST=109.201.167.149 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=6003 DF PROTO=TCP SPT=3998 DPT=37633 WINDOW=65535 RES=0x00 SYN URGP=0
[ 392.887095] IN=ppp0 OUT= MAC= SRC=92.245.122.216 DST=109.201.167.149 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=31014 DF PROTO=TCP SPT=52924 DPT=37633 WINDOW=8192 RES=0x00 SYN URGP=0
[ 395.887348] IN=ppp0 OUT= MAC= SRC=92.245.122.216 DST=109.201.167.149 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=32455 DF PROTO=TCP SPT=52924 DPT=37633 WINDOW=8192 RES=0x00 SYN URGP=0
[ 430.516149] IN=ppp0 OUT= MAC= SRC=77.235.31.11 DST=109.201.167.149 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=48343 DF PROTO=TCP SPT=2074 DPT=37633 WINDOW=65535 RES=0x00 SYN URGP=0
[ 433.402567] IN=ppp0 OUT= MAC= SRC=77.235.31.11 DST=109.201.167.149 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=49048 DF PROTO=TCP SPT=2074 DPT=37633 WINDOW=65535 RES=0x00 SYN URGP=0
[ 439.436639] IN=ppp0 OUT= MAC= SRC=77.235.31.11 DST=109.201.167.149 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=50440 DF PROTO=TCP SPT=2074 DPT=37633 WINDOW=65535 RES=0x00 SYN URGP=0
[ 778.845886] IN=ppp0 OUT= MAC= SRC=92.245.122.216 DST=109.201.167.149 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=18423 DF PROTO=TCP SPT=53682 DPT=37633 WINDOW=8192 RES=0x00 SYN URGP=0
[ 781.851298] IN=ppp0 OUT= MAC= SRC=92.245.122.216 DST=109.201.167.149 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=21175 DF PROTO=TCP SPT=53682 DPT=37633 WINDOW=8192 RES=0x00 SYN URGP=0
[ 807.486757] IN=ppp0 OUT= MAC= SRC=77.235.31.11 DST=109.201.167.149 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=19082 DF PROTO=TCP SPT=3125 DPT=37633 WINDOW=65535 RES=0x00 SYN URGP=0
[ 810.474220] IN=ppp0 OUT= MAC= SRC=77.235.31.11 DST=109.201.167.149 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=19904 DF PROTO=TCP SPT=3125 DPT=37633 WINDOW=65535 RES=0x00 SYN URGP=0
[ 816.409051] IN=ppp0 OUT= MAC= SRC=77.235.31.11 DST=109.201.167.149 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=21489 DF PROTO=TCP SPT=3125 DPT=37633 WINDOW=65535 RES=0x00 SYN URGP=0
[ 917.818578] IN=ppp0 OUT= MAC= SRC=92.245.122.216 DST=109.201.167.149 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=12421 DF PROTO=TCP SPT=53919 DPT=37633 WINDOW=8192 RES=0x00 SYN URGP=0
[ 920.824564] IN=ppp0 OUT= MAC= SRC=92.245.122.216 DST=109.201.167.149 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=12887 DF PROTO=TCP SPT=53919 DPT=37633 WINDOW=8192 RES=0x00 SYN URGP=0
[ 1098.810207] IN=ppp0 OUT= MAC= SRC=92.245.122.216 DST=109.201.167.149 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=4409 DF PROTO=TCP SPT=54227 DPT=37633 WINDOW=8192 RES=0x00 SYN URGP=0
[ 1101.813548] IN=ppp0 OUT= MAC= SRC=92.245.122.216 DST=109.201.167.149 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=4711 DF PROTO=TCP SPT=54227 DPT=37633 WINDOW=8192 RES=0x00 SYN URGP=0
[ 1157.808091] IN=ppp0 OUT= MAC= SRC=92.245.122.216 DST=109.201.167.149 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=10363 DF PROTO=TCP SPT=54339 DPT=37633 WINDOW=8192 RES=0x00 SYN URGP=0
[ 1160.810432] IN=ppp0 OUT= MAC= SRC=92.245.122.216 DST=109.201.167.149 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=10841 DF PROTO=TCP SPT=54339 DPT=37633 WINDOW=8192 RES=0x00 SYN URGP=0
[ 1252.785885] IN=ppp0 OUT= MAC= SRC=92.245.122.216 DST=109.201.167.149 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=25600 DF PROTO=TCP SPT=54502 DPT=37633 WINDOW=8192 RES=0x00 SYN URGP=0
[ 1255.784344] IN=ppp0 OUT= MAC= SRC=92.245.122.216 DST=109.201.167.149 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=25878 DF PROTO=TCP SPT=54502 DPT=37633 WINDOW=8192 RES=0x00 SYN URGP=0
[ 1351.470500] IN=ppp0 OUT= MAC= SRC=77.235.31.11 DST=109.201.167.149 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=41946 DF PROTO=TCP SPT=2147 DPT=37633 WINDOW=65535 RES=0x00 SYN URGP=0
[ 1354.405022] IN=ppp0 OUT= MAC= SRC=77.235.31.11 DST=109.201.167.149 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=42983 DF PROTO=TCP SPT=2147 DPT=37633 WINDOW=65535 RES=0x00 SYN URGP=0
[ 1360.339563] IN=ppp0 OUT= MAC= SRC=77.235.31.11 DST=109.201.167.149 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=45381 DF PROTO=TCP SPT=2147 DPT=37633 WINDOW=65535 RES=0x00 SYN URGP=0
[ 1418.458153] IN=ppp0 OUT= MAC= SRC=77.235.31.11 DST=109.201.167.149 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=2081 DF PROTO=TCP SPT=2890 DPT=37633 WINDOW=65535 RES=0x00 SYN URGP=0
[ 1421.203344] IN=ppp0 OUT= MAC= SRC=77.235.22.30 DST=109.201.167.149 LEN=78 TOS=0x00 PREC=0x00 TTL=127 ID=5712 PROTO=UDP SPT=63127 DPT=137 LEN=58
[ 1421.203408] IN=ppp0 OUT= MAC= SRC=77.235.22.30 DST=109.201.167.149 LEN=78 TOS=0x00 PREC=0x00 TTL=127 ID=5713 PROTO=UDP SPT=63148 DPT=137 LEN=58
[ 1421.203465] IN=ppp0 OUT= MAC= SRC=77.235.22.30 DST=109.201.167.149 LEN=78 TOS=0x00 PREC=0x00 TTL=127 ID=5714 PROTO=UDP SPT=137 DPT=137 LEN=58
[ 1421.390923] IN=ppp0 OUT= MAC= SRC=77.235.31.11 DST=109.201.167.149 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=3034 DF PROTO=TCP SPT=2890 DPT=37633 WINDOW=65535 RES=0x00 SYN URGP=0
[ 1422.701073] IN=ppp0 OUT= MAC= SRC=77.235.22.30 DST=109.201.167.149 LEN=78 TOS=0x00 PREC=0x00 TTL=127 ID=6394 PROTO=UDP SPT=63127 DPT=137 LEN=58
[ 1422.701178] IN=ppp0 OUT= MAC= SRC=77.235.22.30 DST=109.201.167.149 LEN=78 TOS=0x00 PREC=0x00 TTL=127 ID=6395 PROTO=UDP SPT=63148 DPT=137 LEN=58
[ 1422.701250] IN=ppp0 OUT= MAC= SRC=77.235.22.30 DST=109.201.167.149 LEN=78 TOS=0x00 PREC=0x00 TTL=127 ID=6396 PROTO=UDP SPT=137 DPT=137 LEN=58
[ 1424.200188] IN=ppp0 OUT= MAC= SRC=77.235.22.30 DST=109.201.167.149 LEN=78 TOS=0x00 PREC=0x00 TTL=127 ID=7129 PROTO=UDP SPT=63127 DPT=137 LEN=58
[ 1424.200255] IN=ppp0 OUT= MAC= SRC=77.235.22.30 DST=109.201.167.149 LEN=78 TOS=0x00 PREC=0x00 TTL=127 ID=7130 PROTO=UDP SPT=63148 DPT=137 LEN=58
[ 1424.200311] IN=ppp0 OUT= MAC= SRC=77.235.22.30 DST=109.201.167.149 LEN=78 TOS=0x00 PREC=0x00 TTL=127 ID=7131 PROTO=UDP SPT=137 DPT=137 LEN=58
[ 1426.884461] tun: Universal TUN/TAP device driver, 1.6
[ 1426.884468] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1427.426347] IN=ppp0 OUT= MAC= SRC=77.235.31.11 DST=109.201.167.149 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=5155 DF PROTO=TCP SPT=2890 DPT=37633 WINDOW=65535 RES=0x00 SYN URGP=0
[ 1518.773507] IN=ppp0 OUT= MAC= SRC=92.245.122.216 DST=109.201.167.149 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=23164 DF PROTO=TCP SPT=55077 DPT=37633 WINDOW=8192 RES=0x00 SYN URGP=0
[ 1521.777778] IN=ppp0 OUT= MAC= SRC=92.245.122.216 DST=109.201.167.149 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=23340 DF PROTO=TCP SPT=55077 DPT=37633 WINDOW=8192 RES=0x00 SYN URGP=0
[ 1531.426992] IN=ppp0 OUT= MAC= SRC=77.235.31.11 DST=109.201.167.149 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=43010 DF PROTO=TCP SPT=4172 DPT=37633 WINDOW=65535 RES=0x00 SYN URGP=0
[ 1534.341212] IN=ppp0 OUT= MAC= SRC=77.235.31.11 DST=109.201.167.149 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=44006 DF PROTO=TCP SPT=4172 DPT=37633 WINDOW=65535 RES=0x00 SYN URGP=0
[ 1540.375528] IN=ppp0 OUT= MAC= SRC=77.235.31.11 DST=109.201.167.149 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=46349 DF PROTO=TCP SPT=4172 DPT=37633 WINDOW=65535 RES=0x00 SYN URGP=0
[ 1569.080791] IN=ppp0 OUT= MAC= SRC=109.196.124.190 DST=109.201.167.149 LEN=64 TOS=0x00 PREC=0x00 TTL=33 ID=50736 DF PROTO=TCP SPT=2301 DPT=445 WINDOW=53760 RES=0x00 SYN URGP=0
[ 1570.788870] IN=ppp0 OUT= MAC= SRC=92.245.122.216 DST=109.201.167.149 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=25704 DF PROTO=TCP SPT=55183 DPT=37633 WINDOW=8192 RES=0x00 SYN URGP=0
[ 1572.151959] IN=ppp0 OUT= MAC= SRC=109.196.124.190 DST=109.201.167.149 LEN=64 TOS=0x00 PREC=0x00 TTL=33 ID=51659 DF PROTO=TCP SPT=2301 DPT=445 WINDOW=53760 RES=0x00 SYN URGP=0
[ 1573.791968] IN=ppp0 OUT= MAC= SRC=92.245.122.216 DST=109.201.167.149 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=25858 DF PROTO=TCP SPT=55183 DPT=37633 WINDOW=8192 RES=0x00 SYN URGP=0
[ 1639.436509] IN=ppp0 OUT= MAC= SRC=77.235.31.11 DST=109.201.167.149 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=8697 DF PROTO=TCP SPT=1640 DPT=37633 WINDOW=65535 RES=0x00 SYN URGP=0
[ 1642.464900] IN=ppp0 OUT= MAC= SRC=77.235.31.11 DST=109.201.167.149 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=9021 DF PROTO=TCP SPT=1640 DPT=37633 WINDOW=65535 RES=0x00 SYN URGP=0
[ 1648.599204] IN=ppp0 OUT= MAC= SRC=77.235.31.11 DST=109.201.167.149 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=9900 DF PROTO=TCP SPT=1640 DPT=37633 WINDOW=65535 RES=0x00 SYN URGP=0
[ 1730.441677] IN=ppp0 OUT= MAC= SRC=77.235.31.11 DST=109.201.167.149 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=19463 DF PROTO=TCP SPT=2719 DPT=37633 WINDOW=65535 RES=0x00 SYN URGP=0
[ 1733.386421] IN=ppp0 OUT= MAC= SRC=77.235.31.11 DST=109.201.167.149 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=19670 DF PROTO=TCP SPT=2719 DPT=37633 WINDOW=65535 RES=0x00 SYN URGP=0
[ 1739.321879] IN=ppp0 OUT= MAC= SRC=77.235.31.11 DST=109.201.167.149 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=20400 DF PROTO=TCP SPT=2719 DPT=37633 WINDOW=65535 RES=0x00 SYN URGP=0
[ 1755.761305] IN=ppp0 OUT= MAC= SRC=92.245.122.216 DST=109.201.167.149 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=5804 DF PROTO=TCP SPT=55514 DPT=37633 WINDOW=8192 RES=0x00 SYN URGP=0
[ 1758.755532] IN=ppp0 OUT= MAC= SRC=92.245.122.216 DST=109.201.167.149 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=8409 DF PROTO=TCP SPT=55514 DPT=37633 WINDOW=8192 RES=0x00 SYN URGP=0
[ 1954.752743] usb 4-6: USB disconnect, address 3
[ 1955.476044] usb 4-6: new high speed USB device using ehci_hcd and address 4
[ 1955.544241] hub 4-0:1.0: unable to enumerate USB device on port 6
[ 1958.464058] usb 4-6: new high speed USB device using ehci_hcd and address 5
[ 1958.599317] usb 4-6: New USB device found, idVendor=090c, idProduct=1000
[ 1958.599324] usb 4-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1958.599328] usb 4-6: Product: USB DISK
[ 1958.599331] usb 4-6: Manufacturer: SMI Corporation
[ 1958.599334] usb 4-6: SerialNumber: AA04012700008530
[ 1958.599706] usb 4-6: configuration #1 chosen from 1 choice
[ 1958.604412] scsi3 : SCSI emulation for USB Mass Storage devices
[ 1958.606928] usb-storage: device found at 5
[ 1958.606933] usb-storage: waiting for device to settle before scanning
[ 1963.605700] scsi 3:0:0:0: Direct-Access USB Flash Disk 1100 PQ: 0 ANSI: 0 CCS
[ 1963.607272] usb-storage: device scan complete
[ 1963.622698] sd 3:0:0:0: [sda] 1981440 512-byte hardware sectors: (1.01 GB/967 MiB)
[ 1963.623809] sd 3:0:0:0: [sda] Write Protect is off
[ 1963.623816] sd 3:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 1963.623820] sd 3:0:0:0: [sda] Assuming drive cache: write through
[ 1963.629075] sd 3:0:0:0: [sda] Assuming drive cache: write through
[ 1963.629088] sda:<5>sd 3:0:0:0: Attached scsi generic sg0 type 0
[ 1963.741552] sda1
[ 1963.741849] sd 3:0:0:0: [sda] Attached SCSI removable disk
[ 2013.515411] FAT: utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[ 2080.417987] IN=ppp0 OUT= MAC= SRC=77.235.31.11 DST=109.201.167.149 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=19065 DF PROTO=TCP SPT=3741 DPT=37633 WINDOW=65535 RES=0x00 SYN URGP=0
[ 2083.301784] IN=ppp0 OUT= MAC= SRC=77.235.31.11 DST=109.201.167.149 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=22113 DF PROTO=TCP SPT=3741 DPT=37633 WINDOW=65535 RES=0x00 SYN URGP=0
[ 2089.337674] IN=ppp0 OUT= MAC= SRC=77.235.31.11 DST=109.201.167.149 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=28056 DF PROTO=TCP SPT=3741 DPT=37633 WINDOW=65535 RES=0x00 SYN URGP=0
[ 2160.752607] IN=ppp0 OUT= MAC= SRC=92.245.122.216 DST=109.201.167.149 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=8540 DF PROTO=TCP SPT=56227 DPT=37633 WINDOW=8192 RES=0x00 SYN URGP=0
[ 2163.756590] IN=ppp0 OUT= MAC= SRC=92.245.122.216 DST=109.201.167.149 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=8669 DF PROTO=TCP SPT=56227 DPT=37633 WINDOW=8192 RES=0x00 SYN URGP=0
[ 2301.717252] IN=ppp0 OUT= MAC= SRC=92.245.122.216 DST=109.201.167.149 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=17780 DF PROTO=TCP SPT=56470 DPT=37633 WINDOW=8192 RES=0x00 SYN URGP=0
[ 2304.714458] IN=ppp0 OUT= MAC= SRC=92.245.122.216 DST=109.201.167.149 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=17993 DF PROTO=TCP SPT=56470 DPT=37633 WINDOW=8192 RES=0x00 SYN URGP=0
[ 2421.372830] IN=ppp0 OUT= MAC= SRC=77.235.31.11 DST=109.201.167.149 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=38686 DF PROTO=TCP SPT=4386 DPT=37633 WINDOW=65535 RES=0x00 SYN URGP=0
[ 2424.267588] IN=ppp0 OUT= MAC= SRC=77.235.31.11 DST=109.201.167.149 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=38987 DF PROTO=TCP SPT=4386 DPT=37633 WINDOW=65535 RES=0x00 SYN URGP=0
[ 2430.302461] IN=ppp0 OUT= MAC= SRC=77.235.31.11 DST=109.201.167.149 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=39728 DF PROTO=TCP SPT=4386 DPT=37633 WINDOW=65535 RES=0x00 SYN URGP=0
[ 2459.718854] IN=ppp0 OUT= MAC= SRC=92.245.122.216 DST=109.201.167.149 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=29590 DF PROTO=TCP SPT=56778 DPT=37633 WINDOW=8192 RES=0x00 SYN URGP=0
[ 2462.718645] IN=ppp0 OUT= MAC= SRC=92.245.122.216 DST=109.201.167.149 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=29861 DF PROTO=TCP SPT=56778 DPT=37633 WINDOW=8192 RES=0x00 SYN URGP=0
[ 2523.704116] IN=ppp0 OUT= MAC= SRC=92.245.122.216 DST=109.201.167.149 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=1325 DF PROTO=TCP SPT=56900 DPT=37633 WINDOW=8192 RES=0x00 SYN URGP=0
[ 2526.700088] IN=ppp0 OUT= MAC= SRC=92.245.122.216 DST=109.201.167.149 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=1508 DF PROTO=TCP SPT=56900 DPT=37633 WINDOW=8192 RES=0x00 SYN URGP=0
[ 2601.308806] IN=ppp0 OUT= MAC= SRC=77.235.22.30 DST=109.201.167.149 LEN=78 TOS=0x00 PREC=0x00 TTL=127 ID=14351 PROTO=UDP SPT=62203 DPT=137 LEN=58
[ 2601.308870] IN=ppp0 OUT= MAC= SRC=77.235.22.30 DST=109.201.167.149 LEN=78 TOS=0x00 PREC=0x00 TTL=127 ID=14352 PROTO=UDP SPT=62217 DPT=137 LEN=58
[ 2601.308925] IN=ppp0 OUT= MAC= SRC=77.235.22.30 DST=109.201.167.149 LEN=78 TOS=0x00 PREC=0x00 TTL=127 ID=14353 PROTO=UDP SPT=137 DPT=137 LEN=58
[ 2602.809868] IN=ppp0 OUT= MAC= SRC=77.235.22.30 DST=109.201.167.149 LEN=78 TOS=0x00 PREC=0x00 TTL=127 ID=14956 PROTO=UDP SPT=62203 DPT=137 LEN=58
[ 2602.809932] IN=ppp0 OUT= MAC= SRC=77.235.22.30 DST=109.201.167.149 LEN=78 TOS=0x00 PREC=0x00 TTL=127 ID=14957 PROTO=UDP SPT=62217 DPT=137 LEN=58
[ 2602.809987] IN=ppp0 OUT= MAC= SRC=77.235.22.30 DST=109.201.167.149 LEN=78 TOS=0x00 PREC=0x00 TTL=127 ID=14958 PROTO=UDP SPT=137 DPT=137 LEN=58
[ 2604.307211] IN=ppp0 OUT= MAC= SRC=77.235.22.30 DST=109.201.167.149 LEN=78 TOS=0x00 PREC=0x00 TTL=127 ID=15647 PROTO=UDP SPT=62203 DPT=137 LEN=58
[ 2604.307278] IN=ppp0 OUT= MAC= SRC=77.235.22.30 DST=109.201.167.149 LEN=78 TOS=0x00 PREC=0x00 TTL=127 ID=15648 PROTO=UDP SPT=62217 DPT=137 LEN=58
[ 2604.307332] IN=ppp0 OUT= MAC= SRC=77.235.22.30 DST=109.201.167.149 LEN=78 TOS=0x00 PREC=0x00 TTL=127 ID=15649 PROTO=UDP SPT=137 DPT=137 LEN=58
[ 2658.117759] IN=ppp0 OUT= MAC= SRC=77.235.12.38 DST=109.201.167.149 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=3567 DF PROTO=TCP SPT=1959 DPT=6881 WINDOW=65535 RES=0x00 SYN URGP=0
[ 2661.102282] IN=ppp0 OUT= MAC= SRC=77.235.12.38 DST=109.201.167.149 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=4041 DF PROTO=TCP SPT=1959 DPT=6881 WINDOW=65535 RES=0x00 SYN URGP=0
[ 2667.137311] IN=ppp0 OUT= MAC= SRC=77.235.12.38 DST=109.201.167.149 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=4571 DF PROTO=TCP SPT=1959 DPT=6881 WINDOW=65535 RES=0x00 SYN URGP=0
[ 2710.106877] IN=ppp0 OUT= MAC= SRC=77.235.12.38 DST=109.201.167.149 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=6957 DF PROTO=TCP SPT=2279 DPT=6881 WINDOW=65535 RES=0x00 SYN URGP=0
[ 2713.100518] IN=ppp0 OUT= MAC= SRC=77.235.12.38 DST=109.201.167.149 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=7062 DF PROTO=TCP SPT=2279 DPT=6881 WINDOW=65535 RES=0x00 SYN URGP=0
[ 2719.135094] IN=ppp0 OUT= MAC= SRC=77.235.12.38 DST=109.201.167.149 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=7259 DF PROTO=TCP SPT=2279 DPT=6881 WINDOW=65535 RES=0x00 SYN URGP=0
[ 2737.691185] IN=ppp0 OUT= MAC= SRC=92.245.122.216 DST=109.201.167.149 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=7297 DF PROTO=TCP SPT=57404 DPT=37633 WINDOW=8192 RES=0x00 SYN URGP=0
[ 2740.691110] IN=ppp0 OUT= MAC= SRC=92.245.122.216 DST=109.201.167.149 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=9655 DF PROTO=TCP SPT=57404 DPT=37633 WINDOW=8192 RES=0x00 SYN URGP=0
[ 5144.683730] IN=ppp0 OUT= MAC= SRC=77.235.29.161 DST=109.201.170.224 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=51690 DF PROTO=TCP SPT=4422 DPT=24569 WINDOW=65535 RES=0x00 SYN URGP=0
[ 5148.605928] IN=ppp0 OUT= MAC= SRC=77.235.29.161 DST=109.201.170.224 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=52543 DF PROTO=TCP SPT=4514 DPT=24569 WINDOW=65535 RES=0x00 SYN URGP=0
[ 5189.831705] IN=ppp0 OUT= MAC= SRC=92.245.119.197 DST=109.201.170.224 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=27911 DF PROTO=TCP SPT=1204 DPT=445 WINDOW=16384 RES=0x00 SYN URGP=0
[ 5213.570015] usb 4-6: USB disconnect, address 5
[ 5219.608060] usb 4-6: new high speed USB device using ehci_hcd and address 6
[ 5219.740442] usb 4-6: New USB device found, idVendor=1307, idProduct=0163
[ 5219.740449] usb 4-6: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 5219.740828] usb 4-6: configuration #1 chosen from 1 choice
[ 5219.743765] scsi4 : SCSI emulation for USB Mass Storage devices
[ 5219.748285] usb-storage: device found at 6
[ 5219.748291] usb-storage: waiting for device to settle before scanning
[ 5224.748958] scsi 4:0:0:0: Direct-Access USBest USB2FlashStorage 0.00 PQ: 0 ANSI: 2
[ 5224.749547] sd 4:0:0:0: Attached scsi generic sg0 type 0
[ 5224.750828] usb-storage: device scan complete
[ 5224.758653] sd 4:0:0:0: [sda] Attached SCSI removable disk
[ 5227.618410] IN=ppp0 OUT= MAC= SRC=109.201.164.68 DST=109.201.170.224 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=10557 DF PROTO=TCP SPT=2621 DPT=24569 WINDOW=65535 RES=0x00 SYN URGP=0
[ 5230.624323] IN=ppp0 OUT= MAC= SRC=109.201.164.68 DST=109.201.170.224 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=10635 DF PROTO=TCP SPT=2621 DPT=24569 WINDOW=65535 RES=0x00 SYN URGP=0
[ 5236.719217] IN=ppp0 OUT= MAC= SRC=77.235.29.161 DST=109.201.170.224 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=6409 DF PROTO=TCP SPT=2216 DPT=24569 WINDOW=65535 RES=0x00 SYN URGP=0
[ 5239.733039] IN=ppp0 OUT= MAC= SRC=77.235.29.161 DST=109.201.170.224 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=6880 DF PROTO=TCP SPT=2216 DPT=24569 WINDOW=65535 RES=0x00 SYN URGP=0
[ 5245.767971] IN=ppp0 OUT= MAC= SRC=77.235.29.161 DST=109.201.170.224 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=8158 DF PROTO=TCP SPT=2216 DPT=24569 WINDOW=65535 RES=0x00 SYN URGP=0
