Пропадает сеть!
Добавлено: 08 июл 2013, 21:06
Форум сообщества системных администраторов и просто людей, которым не безразличен их компьютер.
https://pkgz.sysadmins.ws/
[spoiler][ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.39.4-4.2-desktop (mandrake@n10.mandriva.com) (gcc version 4.6.1 20110627 (Mandriva) (GCC) ) #1 SMP Fri Nov 4 09:55:28 UTC 2011
[ 0.000000] Command line: BOOT_IMAGE=linux root=UUID=7c33fa14-4939-4567-bdbb-808a54338cd5 nokmsboot resume=UUID=ee03a220-9a49-4b91-aa1c-66f9f1bdb272 splash=silent vga=788
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009f800 (usable)
[ 0.000000] BIOS-e820: 000000000009f800 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 00000000df780000 (usable)
[ 0.000000] BIOS-e820: 00000000df780000 - 00000000df7a3000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000df7a3000 - 00000000df7e0000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000df7e0000 - 00000000df800000 (reserved)
[ 0.000000] BIOS-e820: 00000000f4000000 - 00000000f8000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved)
[ 0.000000] BIOS-e820: 0000000100000000 - 000000021f800000 (usable)
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] DMI 2.4 present.
[ 0.000000] DMI: Gigabyte Technology Co., Ltd. P67X-UD3-B3/P67X-UD3-B3, BIOS F4 04/13/2011
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] No AGP bridge found
[ 0.000000] last_pfn = 0x21f800 max_arch_pfn = 0x400000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CCFFF write-protect
[ 0.000000] CD000-EFFFF uncachable
[ 0.000000] F0000-FFFFF write-through
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask F00000000 write-back
[ 0.000000] 1 base 0E0000000 mask FE0000000 uncachable
[ 0.000000] 2 base 100000000 mask F00000000 write-back
[ 0.000000] 3 base 200000000 mask FE0000000 write-back
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] 8 disabled
[ 0.000000] 9 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820 update range: 00000000e0000000 - 0000000100000000 (usable) ==> (reserved)
[ 0.000000] last_pfn = 0xdf780 max_arch_pfn = 0x400000000
[ 0.000000] found SMP MP-table at [ffff8800000f5c30] f5c30
[ 0.000000] initial memory mapped : 0 - 20000000
[ 0.000000] Base memory trampoline at [ffff88000009a000] 9a000 size 20480
[ 0.000000] init_memory_mapping: 0000000000000000-00000000df780000
[ 0.000000] 0000000000 - 00df600000 page 2M
[ 0.000000] 00df600000 - 00df780000 page 4k
[ 0.000000] kernel direct mapping tables up to df780000 @ df77a000-df780000
[ 0.000000] init_memory_mapping: 0000000100000000-000000021f800000
[ 0.000000] 0100000000 - 021f800000 page 2M
[ 0.000000] kernel direct mapping tables up to 21f800000 @ 21f7f6000-21f800000
[ 0.000000] RAMDISK: 361c0000 - 37ff0000
[ 0.000000] ACPI: RSDP 00000000000f77f0 00014 (v00 GBT )
[ 0.000000] ACPI: RSDT 00000000df7a3040 00050 (v01 GBT GBTUACPI 42302E31 GBTU 01010101)
[ 0.000000] ACPI: FACP 00000000df7a3100 00074 (v01 GBT GBTUACPI 42302E31 GBTU 01010101)
[ 0.000000] ACPI: DSDT 00000000df7a31c0 04D19 (v01 GBT GBTUACPI 00001000 MSFT 04000000)
[ 0.000000] ACPI: FACS 00000000df780000 00040
[ 0.000000] ACPI: HPET 00000000df7a8040 00038 (v01 GBT GBTUACPI 42302E31 GBTU 00000098)
[ 0.000000] ACPI: MCFG 00000000df7a80c0 0003C (v01 GBT GBTUACPI 42302E31 GBTU 01010101)
[ 0.000000] ACPI: ASPT 00000000df7a8200 00034 (v07 GBT PerfTune 312E3042 UTBG 01010101)
[ 0.000000] ACPI: SSPT 00000000df7a8240 0239C (v01 GBT SsptHead 312E3042 UTBG 01010101)
[ 0.000000] ACPI: EUDS 00000000df7aa5e0 000C0 (v01 GBT 00000000 00000000)
[ 0.000000] ACPI: MATS 00000000df7aa6a0 00034 (v01 GBT 00000000 00000000)
[ 0.000000] ACPI: TAMG 00000000df7aa700 00ABA (v01 GBT GBT B0 5455312E BG?? 53450101)
[ 0.000000] ACPI: APIC 00000000df7a7f40 000BC (v01 GBT GBTUACPI 42302E31 GBTU 01010101)
[ 0.000000] ACPI: SSDT 00000000df7ab1c0 03E74 (v01 INTEL PPM RCM 80000001 INTL 20061109)
[ 0.000000] ACPI: MATS 00000000df7af040 09338 (v01 MATS RCM 80000001 INTL 20061109)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] No NUMA configuration found
[ 0.000000] Faking a node at 0000000000000000-000000021f800000
[ 0.000000] NUMA: Using 63 for the hash shift.
[ 0.000000] Initmem setup node 0 0000000000000000-000000021f800000
[ 0.000000] NODE_DATA [000000021f7fb000 - 000000021f7fffff]
[ 0.000000] [ffffea0000000000-ffffea00077fffff] PMD -> [ffff880216e00000-ffff88021dffffff] on node 0
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] DMA32 0x00001000 -> 0x00100000
[ 0.000000] Normal 0x00100000 -> 0x0021f800
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[3] active PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x000df780
[ 0.000000] 0: 0x00100000 -> 0x0021f800
[ 0.000000] On node 0 totalpages: 2092815
[ 0.000000] DMA zone: 56 pages used for memmap
[ 0.000000] DMA zone: 5 pages reserved
[ 0.000000] DMA zone: 3922 pages, LIFO batch:0
[ 0.000000] DMA32 zone: 14280 pages used for memmap
[ 0.000000] DMA32 zone: 896952 pages, LIFO batch:31
[ 0.000000] Normal zone: 16100 pages used for memmap
[ 0.000000] Normal zone: 1161500 pages, LIFO batch:31
[ 0.000000] ACPI: PM-Timer IO Port: 0x408
[ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x02] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x04] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x06] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x05] lapic_id[0x03] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x06] lapic_id[0x05] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x07] lapic_id[0x07] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] dfl dfl lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] dfl dfl lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] dfl dfl lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x03] dfl dfl lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x04] dfl dfl lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x05] dfl dfl lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x06] dfl dfl lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x07] dfl dfl lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.000000] SMP: Allowing 8 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000
[ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[ 0.000000] PM: Registered nosave memory: 00000000df780000 - 00000000df7a3000
[ 0.000000] PM: Registered nosave memory: 00000000df7a3000 - 00000000df7e0000
[ 0.000000] PM: Registered nosave memory: 00000000df7e0000 - 00000000df800000
[ 0.000000] PM: Registered nosave memory: 00000000df800000 - 00000000f4000000
[ 0.000000] PM: Registered nosave memory: 00000000f4000000 - 00000000f8000000
[ 0.000000] PM: Registered nosave memory: 00000000f8000000 - 00000000fec00000
[ 0.000000] PM: Registered nosave memory: 00000000fec00000 - 0000000100000000
[ 0.000000] Allocating PCI resources starting at df800000 (gap: df800000:14800000)
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] setup_percpu: NR_CPUS:64 nr_cpumask_bits:64 nr_cpu_ids:8 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 28 pages/cpu @ffff88021f400000 s83776 r8192 d22720 u262144
[ 0.000000] pcpu-alloc: s83776 r8192 d22720 u262144 alloc=1*2097152
[ 0.000000] pcpu-alloc: [0] 0 1 2 3 4 5 6 7
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2062374
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: BOOT_IMAGE=linux root=UUID=7c33fa14-4939-4567-bdbb-808a54338cd5 nokmsboot resume=UUID=ee03a220-9a49-4b91-aa1c-66f9f1bdb272 splash=silent vga=788
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] xsave/xrstor: enabled xstate_bv 0x7, cntxt size 0x340
[ 0.000000] Checking aperture...
[ 0.000000] Calgary: detecting Calgary via BIOS EBDA area
[ 0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[ 0.000000] Memory: 8145776k/8904704k available (4271k kernel code, 533444k absent, 225484k reserved, 4576k data, 772k init)
[ 0.000000] SLUB: Genslabs=15, HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] RCU-based detection of stalled CPUs is disabled.
[ 0.000000] NR_IRQS:4352 nr_irqs:744 16
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] allocated 67108864 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.001000] Detected 3392.047 MHz processor.
[ 0.000002] Calibrating delay loop (skipped), value calculated using timer frequency.. 6784.09 BogoMIPS (lpj=3392047)
[ 0.000006] pid_max: default: 32768 minimum: 301
[ 0.000023] Security Framework initialized
[ 0.000032] TOMOYO Linux initialized
[ 0.000526] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.002535] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.003414] Mount-cache hash table entries: 256
[ 0.003496] Initializing cgroup subsys ns
[ 0.003499] ns_cgroup deprecated: consider using the 'clone_children' flag without the ns_cgroup.
[ 0.003502] Initializing cgroup subsys cpuacct
[ 0.003505] Initializing cgroup subsys memory
[ 0.003511] Initializing cgroup subsys devices
[ 0.003513] Initializing cgroup subsys freezer
[ 0.003515] Initializing cgroup subsys net_cls
[ 0.003516] Initializing cgroup subsys blkio
[ 0.003521] Initializing cgroup subsys perf_event
[ 0.003539] CPU: Physical Processor ID: 0
[ 0.003541] CPU: Processor Core ID: 0
[ 0.003545] mce: CPU supports 9 MCE banks
[ 0.003555] CPU0: Thermal monitoring enabled (TM1)
[ 0.003561] using mwait in idle threads.
[ 0.004387] ACPI: Checking initramfs for custom DSDT
[ 0.312972] ACPI: Core revision 20110316
[ 0.321290] ftrace: allocating 16942 entries in 67 pages
[ 0.325762] Setting APIC routing to flat
[ 0.326088] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.336901] CPU0: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz stepping 07
[ 0.438126] Performance Events: PEBS fmt1+, SandyBridge events, Intel PMU driver.
[ 0.438132] ... version: 3
[ 0.438133] ... bit width: 48
[ 0.438135] ... generic registers: 4
[ 0.438136] ... value mask: 0000ffffffffffff
[ 0.438138] ... max period: 000000007fffffff
[ 0.438139] ... fixed-purpose events: 3
[ 0.438141] ... event mask: 000000070000000f
[ 0.438355] NMI watchdog enabled, takes one hw-pmu counter.
[ 0.438403] Booting Node 0, Processors #1
[ 0.438405] smpboot cpu 1: start_ip = 9a000
[ 0.528948] NMI watchdog enabled, takes one hw-pmu counter.
[ 0.529007] #2
[ 0.529008] smpboot cpu 2: start_ip = 9a000
[ 0.619646] NMI watchdog enabled, takes one hw-pmu counter.
[ 0.619704] #3
[ 0.619705] smpboot cpu 3: start_ip = 9a000
[ 0.710447] NMI watchdog enabled, takes one hw-pmu counter.
[ 0.710504] #4
[ 0.710506] smpboot cpu 4: start_ip = 9a000
[ 0.801112] NMI watchdog enabled, takes one hw-pmu counter.
[ 0.801176] #5
[ 0.801177] smpboot cpu 5: start_ip = 9a000
[ 0.891917] NMI watchdog enabled, takes one hw-pmu counter.
[ 0.891978] #6
[ 0.891979] smpboot cpu 6: start_ip = 9a000
[ 0.982618] NMI watchdog enabled, takes one hw-pmu counter.
[ 0.982674] #7 Ok.
[ 0.982675] smpboot cpu 7: start_ip = 9a000
[ 1.073314] NMI watchdog enabled, takes one hw-pmu counter.
[ 1.073338] Brought up 8 CPUs
[ 1.073340] Total of 8 processors activated (54270.11 BogoMIPS).
[ 1.077463] devtmpfs: initialized
[ 1.077988] PM: Registering ACPI NVS region at df780000 (143360 bytes)
[ 1.078452] Time: 21:11:53 Date: 07/09/13
[ 1.078473] NET: Registered protocol family 16
[ 1.078547] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 1.078550] ACPI: bus type pci registered
[ 1.078589] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf4000000-0xf7ffffff] (base 0xf4000000)
[ 1.078593] PCI: MMCONFIG at [mem 0xf4000000-0xf7ffffff] reserved in E820
[ 1.084334] PCI: Using configuration type 1 for base access
[ 1.084627] bio: create slab <bio-0> at 0
[ 1.085109] ACPI: EC: Look up EC in DSDT
[ 1.088696] ACPI Warning: Incorrect checksum in table [TAMG] - 0x84, should be 0x83 (20110316/tbutils-314)
[ 1.089233] ACPI: Interpreter enabled
[ 1.089236] ACPI: (supports S0 S3 S4 S5)
[ 1.089247] ACPI: Using IOAPIC for interrupt routing
[ 1.091011] ACPI: No dock devices found.
[ 1.091013] HEST: Table not found.
[ 1.091015] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 1.091044] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3f])
[ 1.091092] pci_root PNP0A03:00: host bridge window [io 0x0000-0x0cf7]
[ 1.091095] pci_root PNP0A03:00: host bridge window [io 0x0d00-0xffff]
[ 1.091097] pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff]
[ 1.091100] pci_root PNP0A03:00: host bridge window [mem 0x000c0000-0x000dffff]
[ 1.091102] pci_root PNP0A03:00: host bridge window [mem 0xfed40000-0xfed44fff]
[ 1.091105] pci_root PNP0A03:00: host bridge window [mem 0xe0000000-0xfebfffff]
[ 1.091113] pci 0000:00:00.0: [8086:0100] type 0 class 0x000600
[ 1.091137] pci 0000:00:01.0: [8086:0101] type 1 class 0x000604
[ 1.091153] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 1.091155] pci 0000:00:01.0: PME# disabled
[ 1.091193] pci 0000:00:16.0: [8086:1c3a] type 0 class 0x000780
[ 1.091213] pci 0000:00:16.0: reg 10: [mem 0xfbfff000-0xfbfff00f 64bit]
[ 1.091268] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[ 1.091271] pci 0000:00:16.0: PME# disabled
[ 1.091297] pci 0000:00:1a.0: [8086:1c2d] type 0 class 0x000c03
[ 1.091316] pci 0000:00:1a.0: reg 10: [mem 0xfbffe000-0xfbffe3ff]
[ 1.091381] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[ 1.091384] pci 0000:00:1a.0: PME# disabled
[ 1.091403] pci 0000:00:1b.0: [8086:1c20] type 0 class 0x000403
[ 1.091416] pci 0000:00:1b.0: reg 10: [mem 0xfbff8000-0xfbffbfff 64bit]
[ 1.091463] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 1.091466] pci 0000:00:1b.0: PME# disabled
[ 1.091482] pci 0000:00:1c.0: [8086:1c10] type 1 class 0x000604
[ 1.091537] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 1.091540] pci 0000:00:1c.0: PME# disabled
[ 1.091560] pci 0000:00:1c.3: [8086:244e] type 1 class 0x000604
[ 1.091615] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 1.091618] pci 0000:00:1c.3: PME# disabled
[ 1.091636] pci 0000:00:1c.4: [8086:1c18] type 1 class 0x000604
[ 1.091691] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[ 1.091694] pci 0000:00:1c.4: PME# disabled
[ 1.091712] pci 0000:00:1c.5: [8086:1c1a] type 1 class 0x000604
[ 1.091767] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
[ 1.091769] pci 0000:00:1c.5: PME# disabled
[ 1.091789] pci 0000:00:1c.6: [8086:1c1c] type 1 class 0x000604
[ 1.091843] pci 0000:00:1c.6: PME# supported from D0 D3hot D3cold
[ 1.091846] pci 0000:00:1c.6: PME# disabled
[ 1.091865] pci 0000:00:1c.7: [8086:1c1e] type 1 class 0x000604
[ 1.091920] pci 0000:00:1c.7: PME# supported from D0 D3hot D3cold
[ 1.091922] pci 0000:00:1c.7: PME# disabled
[ 1.091945] pci 0000:00:1d.0: [8086:1c26] type 0 class 0x000c03
[ 1.091964] pci 0000:00:1d.0: reg 10: [mem 0xfbffd000-0xfbffd3ff]
[ 1.092029] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 1.092032] pci 0000:00:1d.0: PME# disabled
[ 1.092051] pci 0000:00:1f.0: [8086:1c46] type 0 class 0x000601
[ 1.092150] pci 0000:00:1f.2: [8086:1c00] type 0 class 0x000101
[ 1.092163] pci 0000:00:1f.2: reg 10: [io 0xff00-0xff07]
[ 1.092171] pci 0000:00:1f.2: reg 14: [io 0xfe00-0xfe03]
[ 1.092177] pci 0000:00:1f.2: reg 18: [io 0xfd00-0xfd07]
[ 1.092183] pci 0000:00:1f.2: reg 1c: [io 0xfc00-0xfc03]
[ 1.092190] pci 0000:00:1f.2: reg 20: [io 0xfb00-0xfb0f]
[ 1.092196] pci 0000:00:1f.2: reg 24: [io 0xfa00-0xfa0f]
[ 1.092226] pci 0000:00:1f.3: [8086:1c22] type 0 class 0x000c05
[ 1.092239] pci 0000:00:1f.3: reg 10: [mem 0xfbffc000-0xfbffc0ff 64bit]
[ 1.092258] pci 0000:00:1f.3: reg 20: [io 0x0500-0x051f]
[ 1.092284] pci 0000:00:1f.5: [8086:1c08] type 0 class 0x000101
[ 1.092296] pci 0000:00:1f.5: reg 10: [io 0xf800-0xf807]
[ 1.092303] pci 0000:00:1f.5: reg 14: [io 0xf700-0xf703]
[ 1.092309] pci 0000:00:1f.5: reg 18: [io 0xf600-0xf607]
[ 1.092315] pci 0000:00:1f.5: reg 1c: [io 0xf500-0xf503]
[ 1.092321] pci 0000:00:1f.5: reg 20: [io 0xf400-0xf40f]
[ 1.092328] pci 0000:00:1f.5: reg 24: [io 0xf300-0xf30f]
[ 1.092375] pci 0000:01:00.0: [10de:0de1] type 0 class 0x000300
[ 1.092382] pci 0000:01:00.0: reg 10: [mem 0xf9000000-0xf9ffffff]
[ 1.092390] pci 0000:01:00.0: reg 14: [mem 0xe0000000-0xe7ffffff 64bit pref]
[ 1.092398] pci 0000:01:00.0: reg 1c: [mem 0xee000000-0xefffffff 64bit pref]
[ 1.092403] pci 0000:01:00.0: reg 24: [io 0xbf00-0xbf7f]
[ 1.092409] pci 0000:01:00.0: reg 30: [mem 0x00000000-0x0007ffff pref]
[ 1.092442] pci 0000:01:00.1: [10de:0bea] type 0 class 0x000403
[ 1.092449] pci 0000:01:00.1: reg 10: [mem 0xfaffc000-0xfaffffff]
[ 1.092505] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 1.092508] pci 0000:00:01.0: bridge window [io 0xb000-0xbfff]
[ 1.092509] pci 0000:00:01.0: bridge window [mem 0xf9000000-0xfaffffff]
[ 1.092512] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xefffffff 64bit pref]
[ 1.092551] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 1.092555] pci 0000:00:1c.0: bridge window [io 0xf000-0x0000] (disabled)
[ 1.092558] pci 0000:00:1c.0: bridge window [mem 0xfff00000-0x000fffff] (disabled)
[ 1.092563] pci 0000:00:1c.0: bridge window [mem 0xfff00000-0x000fffff pref] (disabled)
[ 1.092623] pci 0000:03:00.0: [1283:8892] type 1 class 0x000604
[ 1.092747] pci 0000:03:00.0: supports D1 D2
[ 1.092748] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.092753] pci 0000:03:00.0: PME# disabled
[ 1.092776] pci 0000:00:1c.3: PCI bridge to [bus 03-04] (subtractive decode)
[ 1.092780] pci 0000:00:1c.3: bridge window [io 0xe000-0xefff]
[ 1.092783] pci 0000:00:1c.3: bridge window [mem 0xfbb00000-0xfbbfffff]
[ 1.092787] pci 0000:00:1c.3: bridge window [mem 0xfff00000-0x000fffff pref] (disabled)
[ 1.092789] pci 0000:00:1c.3: bridge window [io 0x0000-0x0cf7] (subtractive decode)
[ 1.092790] pci 0000:00:1c.3: bridge window [io 0x0d00-0xffff] (subtractive decode)
[ 1.092791] pci 0000:00:1c.3: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 1.092793] pci 0000:00:1c.3: bridge window [mem 0x000c0000-0x000dffff] (subtractive decode)
[ 1.092794] pci 0000:00:1c.3: bridge window [mem 0xfed40000-0xfed44fff] (subtractive decode)
[ 1.092795] pci 0000:00:1c.3: bridge window [mem 0xe0000000-0xfebfffff] (subtractive decode)
[ 1.092880] pci 0000:04:00.0: [168c:0029] type 0 class 0x000280
[ 1.092915] pci 0000:04:00.0: reg 10: [mem 0xfbbe0000-0xfbbeffff]
[ 1.093062] pci 0000:04:00.0: PME# supported from D0 D3hot
[ 1.093068] pci 0000:04:00.0: PME# disabled
[ 1.093101] pci 0000:04:02.0: [1106:3044] type 0 class 0x000c00
[ 1.093137] pci 0000:04:02.0: reg 10: [mem 0xfbbff000-0xfbbff7ff]
[ 1.093156] pci 0000:04:02.0: reg 14: [io 0xef00-0xef7f]
[ 1.093287] pci 0000:04:02.0: supports D2
[ 1.093289] pci 0000:04:02.0: PME# supported from D2 D3hot D3cold
[ 1.093295] pci 0000:04:02.0: PME# disabled
[ 1.093381] pci 0000:03:00.0: PCI bridge to [bus 04-04] (subtractive decode)
[ 1.093393] pci 0000:03:00.0: bridge window [io 0xe000-0xefff]
[ 1.093399] pci 0000:03:00.0: bridge window [mem 0xfbb00000-0xfbbfffff]
[ 1.093409] pci 0000:03:00.0: bridge window [mem 0xfff00000-0x000fffff pref] (disabled)
[ 1.093410] pci 0000:03:00.0: bridge window [io 0xe000-0xefff] (subtractive decode)
[ 1.093412] pci 0000:03:00.0: bridge window [mem 0xfbb00000-0xfbbfffff] (subtractive decode)
[ 1.093413] pci 0000:03:00.0: bridge window [??? 0x00000000 flags 0x0] (subtractive decode)
[ 1.093415] pci 0000:03:00.0: bridge window [??? 0x00000000 flags 0x0] (subtractive decode)
[ 1.093416] pci 0000:03:00.0: bridge window [io 0x0000-0x0cf7] (subtractive decode)
[ 1.093418] pci 0000:03:00.0: bridge window [io 0x0d00-0xffff] (subtractive decode)
[ 1.093420] pci 0000:03:00.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 1.093421] pci 0000:03:00.0: bridge window [mem 0x000c0000-0x000dffff] (subtractive decode)
[ 1.093422] pci 0000:03:00.0: bridge window [mem 0xfed40000-0xfed44fff] (subtractive decode)
[ 1.093424] pci 0000:03:00.0: bridge window [mem 0xe0000000-0xfebfffff] (subtractive decode)
[ 1.093493] pci 0000:05:00.0: [1b6f:7023] type 0 class 0x000c03
[ 1.093517] pci 0000:05:00.0: reg 10: [mem 0xfbaf8000-0xfbafffff 64bit]
[ 1.093610] pci 0000:05:00.0: supports D1 D2
[ 1.093611] pci 0000:05:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.093616] pci 0000:05:00.0: PME# disabled
[ 1.093644] pci 0000:00:1c.4: PCI bridge to [bus 05-05]
[ 1.093648] pci 0000:00:1c.4: bridge window [io 0xf000-0x0000] (disabled)
[ 1.093651] pci 0000:00:1c.4: bridge window [mem 0xfba00000-0xfbafffff]
[ 1.093656] pci 0000:00:1c.4: bridge window [mem 0xfff00000-0x000fffff pref] (disabled)
[ 1.093713] pci 0000:06:00.0: [1b6f:7023] type 0 class 0x000c03
[ 1.093737] pci 0000:06:00.0: reg 10: [mem 0xfbef8000-0xfbefffff 64bit]
[ 1.093831] pci 0000:06:00.0: supports D1 D2
[ 1.093832] pci 0000:06:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.093836] pci 0000:06:00.0: PME# disabled
[ 1.093865] pci 0000:00:1c.5: PCI bridge to [bus 06-06]
[ 1.093869] pci 0000:00:1c.5: bridge window [io 0xf000-0x0000] (disabled)
[ 1.093872] pci 0000:00:1c.5: bridge window [mem 0xfbe00000-0xfbefffff]
[ 1.093877] pci 0000:00:1c.5: bridge window [mem 0xfff00000-0x000fffff pref] (disabled)
[ 1.093934] pci 0000:07:00.0: [10ec:8168] type 0 class 0x000200
[ 1.093952] pci 0000:07:00.0: reg 10: [io 0xde00-0xdeff]
[ 1.093983] pci 0000:07:00.0: reg 18: [mem 0xfbdff000-0xfbdfffff 64bit pref]
[ 1.094003] pci 0000:07:00.0: reg 20: [mem 0xfbdf8000-0xfbdfbfff 64bit pref]
[ 1.094059] pci 0000:07:00.0: supports D1 D2
[ 1.094060] pci 0000:07:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.094064] pci 0000:07:00.0: PME# disabled
[ 1.094102] pci 0000:00:1c.6: PCI bridge to [bus 07-07]
[ 1.094106] pci 0000:00:1c.6: bridge window [io 0xd000-0xdfff]
[ 1.094109] pci 0000:00:1c.6: bridge window [mem 0xfff00000-0x000fffff] (disabled)
[ 1.094114] pci 0000:00:1c.6: bridge window [mem 0xfbd00000-0xfbdfffff 64bit pref]
[ 1.094170] pci 0000:08:00.0: [1b4b:917a] type 0 class 0x000101
[ 1.094186] pci 0000:08:00.0: reg 10: [io 0xcf00-0xcf07]
[ 1.094198] pci 0000:08:00.0: reg 14: [io 0xce00-0xce03]
[ 1.094209] pci 0000:08:00.0: reg 18: [io 0xcd00-0xcd07]
[ 1.094221] pci 0000:08:00.0: reg 1c: [io 0xcc00-0xcc03]
[ 1.094232] pci 0000:08:00.0: reg 20: [io 0xcb00-0xcb0f]
[ 1.094244] pci 0000:08:00.0: reg 24: [mem 0xfbcff000-0xfbcff1ff]
[ 1.094256] pci 0000:08:00.0: reg 30: [mem 0x00000000-0x0000ffff pref]
[ 1.094289] pci 0000:08:00.0: PME# supported from D3hot
[ 1.094293] pci 0000:08:00.0: PME# disabled
[ 1.094315] pci 0000:00:1c.7: PCI bridge to [bus 08-08]
[ 1.094319] pci 0000:00:1c.7: bridge window [io 0xc000-0xcfff]
[ 1.094322] pci 0000:00:1c.7: bridge window [mem 0xfbc00000-0xfbcfffff]
[ 1.094327] pci 0000:00:1c.7: bridge window [mem 0xfff00000-0x000fffff pref] (disabled)
[ 1.094354] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 1.094420] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEG0._PRT]
[ 1.094435] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX0._PRT]
[ 1.094451] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX3._PRT]
[ 1.094465] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX4._PRT]
[ 1.094478] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX5._PRT]
[ 1.094491] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX6._PRT]
[ 1.094505] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX7._PRT]
[ 1.094529] pci0000:00: Requesting ACPI _OSC control (0x1d)
[ 1.094532] Unable to assume _OSC PCIe control. Disabling ASPM
[ 1.098353] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 11 *12 14 15)
[ 1.098380] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 *7 9 10 11 12 14 15)
[ 1.098405] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 9 *10 11 12 14 15)
[ 1.098430] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 10 *11 12 14 15)
[ 1.098455] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
[ 1.098481] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
[ 1.098507] ACPI: PCI Interrupt Link [LNK0] (IRQs 3 4 *5 6 7 9 10 11 12 14 15)
[ 1.098531] ACPI: PCI Interrupt Link [LNK1] (IRQs *3 4 5 6 7 9 10 11 12 14 15)
[ 1.098583] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 1.098588] vgaarb: loaded
[ 1.098621] PCI: Using ACPI for IRQ routing
[ 1.098623] PCI: pci_cache_line_size set to 64 bytes
[ 1.098698] reserve RAM buffer: 000000000009f800 - 000000000009ffff
[ 1.098700] reserve RAM buffer: 00000000df780000 - 00000000dfffffff
[ 1.098701] reserve RAM buffer: 000000021f800000 - 000000021fffffff
[ 1.098747] NetLabel: Initializing
[ 1.098749] NetLabel: domain hash size = 128
[ 1.098751] NetLabel: protocols = UNLABELED CIPSOv4
[ 1.098758] NetLabel: unlabeled traffic allowed by default
[ 1.098766] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 1.098771] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 1.100780] Switching to clocksource hpet
[ 1.101147] Switched to NOHz mode on CPU #0
[ 1.101199] Switched to NOHz mode on CPU #2
[ 1.101208] Switched to NOHz mode on CPU #4
[ 1.101224] Switched to NOHz mode on CPU #7
[ 1.101228] Switched to NOHz mode on CPU #1
[ 1.101256] Switched to NOHz mode on CPU #6
[ 1.101270] Switched to NOHz mode on CPU #3
[ 1.101283] Switched to NOHz mode on CPU #5
[ 1.103428] pnp: PnP ACPI init
[ 1.103434] ACPI: bus type pnp registered
[ 1.103470] pnp 00:00: [bus 00-3f]
[ 1.103471] pnp 00:00: [io 0x0cf8-0x0cff]
[ 1.103473] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 1.103474] pnp 00:00: [io 0x0d00-0xffff window]
[ 1.103475] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 1.103476] pnp 00:00: [mem 0x000c0000-0x000dffff window]
[ 1.103477] pnp 00:00: [mem 0xfed40000-0xfed44fff window]
[ 1.103478] pnp 00:00: [mem 0xe0000000-0xfebfffff window]
[ 1.103498] pnp 00:00: Plug and Play ACPI device, IDs PNP0a03 (active)
[ 1.103538] pnp 00:01: [io 0x0010-0x001f]
[ 1.103539] pnp 00:01: [io 0x0022-0x003f]
[ 1.103540] pnp 00:01: [io 0x0044-0x004d]
[ 1.103540] pnp 00:01: [io 0x0050-0x005f]
[ 1.103543] pnp 00:01: [io 0x0062-0x0063]
[ 1.103543] pnp 00:01: [io 0x0065-0x006f]
[ 1.103544] pnp 00:01: [io 0x0074-0x007f]
[ 1.103545] pnp 00:01: [io 0x0091-0x0093]
[ 1.103546] pnp 00:01: [io 0x00a2-0x00bf]
[ 1.103547] pnp 00:01: [io 0x00e0-0x00ef]
[ 1.103548] pnp 00:01: [io 0x04d0-0x04d1]
[ 1.103549] pnp 00:01: [io 0x0290-0x029f]
[ 1.103550] pnp 00:01: [io 0x0800-0x0805]
[ 1.103551] pnp 00:01: [io 0x0290-0x0294]
[ 1.103552] pnp 00:01: [io 0x0880-0x088f]
[ 1.103579] system 00:01: [io 0x04d0-0x04d1] has been reserved
[ 1.103583] system 00:01: [io 0x0290-0x029f] has been reserved
[ 1.103585] system 00:01: [io 0x0800-0x0805] has been reserved
[ 1.103587] system 00:01: [io 0x0290-0x0294] has been reserved
[ 1.103589] system 00:01: [io 0x0880-0x088f] has been reserved
[ 1.103592] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 1.103598] pnp 00:02: [dma 4]
[ 1.103599] pnp 00:02: [io 0x0000-0x000f]
[ 1.103600] pnp 00:02: [io 0x0080-0x0090]
[ 1.103601] pnp 00:02: [io 0x0094-0x009f]
[ 1.103602] pnp 00:02: [io 0x00c0-0x00df]
[ 1.103612] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 1.103637] pnp 00:03: [irq 0 disabled]
[ 1.103642] pnp 00:03: [irq 8]
[ 1.103643] pnp 00:03: [mem 0xfed00000-0xfed003ff]
[ 1.103654] pnp 00:03: Plug and Play ACPI device, IDs PNP0103 (active)
[ 1.103669] pnp 00:04: [io 0x0070-0x0073]
[ 1.103680] pnp 00:04: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 1.103684] pnp 00:05: [io 0x0061]
[ 1.103694] pnp 00:05: Plug and Play ACPI device, IDs PNP0800 (active)
[ 1.103699] pnp 00:06: [io 0x00f0-0x00ff]
[ 1.103702] pnp 00:06: [irq 13]
[ 1.103713] pnp 00:06: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 1.103856] pnp 00:07: [io 0x03f8-0x03ff]
[ 1.103859] pnp 00:07: [irq 4]
[ 1.103888] pnp 00:07: Plug and Play ACPI device, IDs PNP0501 (active)
[ 1.103910] pnp 00:08: [io 0x0060]
[ 1.103911] pnp 00:08: [io 0x0064]
[ 1.103914] pnp 00:08: [irq 1]
[ 1.103928] pnp 00:08: Plug and Play ACPI device, IDs PNP0303 (active)
[ 1.103947] pnp 00:09: [io 0x0400-0x04cf]
[ 1.103948] pnp 00:09: [io 0x04d2-0x04ff]
[ 1.103969] system 00:09: [io 0x0400-0x04cf] has been reserved
[ 1.103971] system 00:09: [io 0x04d2-0x04ff] has been reserved
[ 1.103974] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 1.103980] pnp 00:0a: [io 0x1000-0x107f]
[ 1.103981] pnp 00:0a: [io 0x1080-0x10ff]
[ 1.103982] pnp 00:0a: [io 0x1100-0x117f]
[ 1.103984] pnp 00:0a: [io 0x1180-0x11ff]
[ 1.104006] system 00:0a: [io 0x1000-0x107f] has been reserved
[ 1.104008] system 00:0a: [io 0x1080-0x10ff] has been reserved
[ 1.104010] system 00:0a: [io 0x1100-0x117f] has been reserved
[ 1.104012] system 00:0a: [io 0x1180-0x11ff] has been reserved
[ 1.104015] system 00:0a: Plug and Play ACPI device, IDs ICD0001 PNP0c02 (active)
[ 1.104104] pnp 00:0b: [io 0x0454-0x0457]
[ 1.104129] system 00:0b: [io 0x0454-0x0457] has been reserved
[ 1.104132] system 00:0b: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 1.104141] pnp 00:0c: [mem 0xf4000000-0xf7ffffff]
[ 1.104165] system 00:0c: [mem 0xf4000000-0xf7ffffff] has been reserved
[ 1.104168] system 00:0c: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 1.104252] pnp 00:0d: [mem 0x000cda00-0x000cffff]
[ 1.104253] pnp 00:0d: [mem 0x000f0000-0x000f7fff]
[ 1.104254] pnp 00:0d: [mem 0x000f8000-0x000fbfff]
[ 1.104255] pnp 00:0d: [mem 0x000fc000-0x000fffff]
[ 1.104256] pnp 00:0d: [mem 0xdf780000-0xdf7dffff]
[ 1.104257] pnp 00:0d: [mem 0x00000000-0x0009ffff]
[ 1.104258] pnp 00:0d: [mem 0x00100000-0xdf77ffff]
[ 1.104259] pnp 00:0d: [mem 0xdf7e0000-0xdf7fffff]
[ 1.104260] pnp 00:0d: [mem 0xfec00000-0xfec00fff]
[ 1.104261] pnp 00:0d: [mem 0xfed10000-0xfed1dfff]
[ 1.104262] pnp 00:0d: [mem 0xfed20000-0xfed8ffff]
[ 1.104263] pnp 00:0d: [mem 0xfee00000-0xfee00fff]
[ 1.104264] pnp 00:0d: [mem 0xffb00000-0xffb7ffff]
[ 1.104265] pnp 00:0d: [mem 0xfff00000-0xffffffff]
[ 1.104266] pnp 00:0d: [mem 0x000e0000-0x000effff]
[ 1.104267] pnp 00:0d: [mem 0x20000000-0x201fffff]
[ 1.104268] pnp 00:0d: [mem 0x40000000-0x400fffff]
[ 1.104269] pnp 00:0d: [mem 0xdf800000-0xdfffffff]
[ 1.104304] system 00:0d: [mem 0x000cda00-0x000cffff] has been reserved
[ 1.104307] system 00:0d: [mem 0x000f0000-0x000f7fff] could not be reserved
[ 1.104310] system 00:0d: [mem 0x000f8000-0x000fbfff] could not be reserved
[ 1.104312] system 00:0d: [mem 0x000fc000-0x000fffff] could not be reserved
[ 1.104314] system 00:0d: [mem 0xdf780000-0xdf7dffff] could not be reserved
[ 1.104317] system 00:0d: [mem 0x00000000-0x0009ffff] could not be reserved
[ 1.104319] system 00:0d: [mem 0x00100000-0xdf77ffff] could not be reserved
[ 1.104322] system 00:0d: [mem 0xdf7e0000-0xdf7fffff] has been reserved
[ 1.104324] system 00:0d: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 1.104326] system 00:0d: [mem 0xfed10000-0xfed1dfff] has been reserved
[ 1.104329] system 00:0d: [mem 0xfed20000-0xfed8ffff] could not be reserved
[ 1.104331] system 00:0d: [mem 0xfee00000-0xfee00fff] has been reserved
[ 1.104334] system 00:0d: [mem 0xffb00000-0xffb7ffff] has been reserved
[ 1.104336] system 00:0d: [mem 0xfff00000-0xffffffff] has been reserved
[ 1.104338] system 00:0d: [mem 0x000e0000-0x000effff] has been reserved
[ 1.104341] system 00:0d: [mem 0x20000000-0x201fffff] could not be reserved
[ 1.104343] system 00:0d: [mem 0x40000000-0x400fffff] could not be reserved
[ 1.104346] system 00:0d: [mem 0xdf800000-0xdfffffff] could not be reserved
[ 1.104348] system 00:0d: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 1.104357] pnp 00:0e: [mem 0xffb80000-0xffbfffff]
[ 1.104373] pnp 00:0e: Plug and Play ACPI device, IDs INT0800 (active)
[ 1.104377] pnp: PnP ACPI: found 15 devices
[ 1.104378] ACPI: ACPI bus type pnp unregistered
[ 1.109534] pci 0000:00:1c.7: BAR 15: assigned [mem 0xf0000000-0xf00fffff pref]
[ 1.109538] pci 0000:00:1c.0: BAR 14: assigned [mem 0xf0100000-0xf02fffff]
[ 1.109542] pci 0000:00:1c.0: BAR 15: assigned [mem 0xf0300000-0xf04fffff 64bit pref]
[ 1.109545] pci 0000:00:1c.0: BAR 13: assigned [io 0x2000-0x2fff]
[ 1.109548] pci 0000:01:00.0: BAR 6: assigned [mem 0xe8000000-0xe807ffff pref]
[ 1.109551] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 1.109553] pci 0000:00:01.0: bridge window [io 0xb000-0xbfff]
[ 1.109556] pci 0000:00:01.0: bridge window [mem 0xf9000000-0xfaffffff]
[ 1.109559] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xefffffff 64bit pref]
[ 1.109563] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 1.109566] pci 0000:00:1c.0: bridge window [io 0x2000-0x2fff]
[ 1.109570] pci 0000:00:1c.0: bridge window [mem 0xf0100000-0xf02fffff]
[ 1.109575] pci 0000:00:1c.0: bridge window [mem 0xf0300000-0xf04fffff 64bit pref]
[ 1.109581] pci 0000:03:00.0: PCI bridge to [bus 04-04]
[ 1.109585] pci 0000:03:00.0: bridge window [io 0xe000-0xefff]
[ 1.109594] pci 0000:03:00.0: bridge window [mem 0xfbb00000-0xfbbfffff]
[ 1.109601] pci 0000:03:00.0: bridge window [mem pref disabled]
[ 1.109612] pci 0000:00:1c.3: PCI bridge to [bus 03-04]
[ 1.109615] pci 0000:00:1c.3: bridge window [io 0xe000-0xefff]
[ 1.109620] pci 0000:00:1c.3: bridge window [mem 0xfbb00000-0xfbbfffff]
[ 1.109624] pci 0000:00:1c.3: bridge window [mem pref disabled]
[ 1.109630] pci 0000:00:1c.4: PCI bridge to [bus 05-05]
[ 1.109632] pci 0000:00:1c.4: bridge window [io disabled]
[ 1.109636] pci 0000:00:1c.4: bridge window [mem 0xfba00000-0xfbafffff]
[ 1.109640] pci 0000:00:1c.4: bridge window [mem pref disabled]
[ 1.109646] pci 0000:00:1c.5: PCI bridge to [bus 06-06]
[ 1.109648] pci 0000:00:1c.5: bridge window [io disabled]
[ 1.109652] pci 0000:00:1c.5: bridge window [mem 0xfbe00000-0xfbefffff]
[ 1.109656] pci 0000:00:1c.5: bridge window [mem pref disabled]
[ 1.109662] pci 0000:00:1c.6: PCI bridge to [bus 07-07]
[ 1.109665] pci 0000:00:1c.6: bridge window [io 0xd000-0xdfff]
[ 1.109670] pci 0000:00:1c.6: bridge window [mem disabled]
[ 1.109673] pci 0000:00:1c.6: bridge window [mem 0xfbd00000-0xfbdfffff 64bit pref]
[ 1.109680] pci 0000:08:00.0: BAR 6: assigned [mem 0xf0000000-0xf000ffff pref]
[ 1.109683] pci 0000:00:1c.7: PCI bridge to [bus 08-08]
[ 1.109686] pci 0000:00:1c.7: bridge window [io 0xc000-0xcfff]
[ 1.109690] pci 0000:00:1c.7: bridge window [mem 0xfbc00000-0xfbcfffff]
[ 1.109694] pci 0000:00:1c.7: bridge window [mem 0xf0000000-0xf00fffff pref]
[ 1.109707] pci 0000:00:01.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 1.109710] pci 0000:00:01.0: setting latency timer to 64
[ 1.109714] pci 0000:00:1c.0: enabling device (0000 -> 0003)
[ 1.109717] pci 0000:00:1c.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 1.109722] pci 0000:00:1c.0: setting latency timer to 64
[ 1.109728] pci 0000:00:1c.3: PCI INT D -> GSI 19 (level, low) -> IRQ 19
[ 1.109732] pci 0000:00:1c.3: setting latency timer to 64
[ 1.109740] pci 0000:03:00.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[ 1.109747] pci 0000:03:00.0: setting latency timer to 64
[ 1.109752] pci 0000:00:1c.4: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 1.109756] pci 0000:00:1c.4: setting latency timer to 64
[ 1.109762] pci 0000:00:1c.5: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[ 1.109766] pci 0000:00:1c.5: setting latency timer to 64
[ 1.109772] pci 0000:00:1c.6: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 1.109776] pci 0000:00:1c.6: setting latency timer to 64
[ 1.109780] pci 0000:00:1c.7: PCI INT D -> GSI 19 (level, low) -> IRQ 19
[ 1.109784] pci 0000:00:1c.7: setting latency timer to 64
[ 1.109787] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 1.109788] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 1.109789] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 1.109790] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000dffff]
[ 1.109792] pci_bus 0000:00: resource 8 [mem 0xfed40000-0xfed44fff]
[ 1.109793] pci_bus 0000:00: resource 9 [mem 0xe0000000-0xfebfffff]
[ 1.109794] pci_bus 0000:01: resource 0 [io 0xb000-0xbfff]
[ 1.109795] pci_bus 0000:01: resource 1 [mem 0xf9000000-0xfaffffff]
[ 1.109796] pci_bus 0000:01: resource 2 [mem 0xe0000000-0xefffffff 64bit pref]
[ 1.109798] pci_bus 0000:02: resource 0 [io 0x2000-0x2fff]
[ 1.109799] pci_bus 0000:02: resource 1 [mem 0xf0100000-0xf02fffff]
[ 1.109800] pci_bus 0000:02: resource 2 [mem 0xf0300000-0xf04fffff 64bit pref]
[ 1.109801] pci_bus 0000:03: resource 0 [io 0xe000-0xefff]
[ 1.109802] pci_bus 0000:03: resource 1 [mem 0xfbb00000-0xfbbfffff]
[ 1.109804] pci_bus 0000:03: resource 4 [io 0x0000-0x0cf7]
[ 1.109805] pci_bus 0000:03: resource 5 [io 0x0d00-0xffff]
[ 1.109806] pci_bus 0000:03: resource 6 [mem 0x000a0000-0x000bffff]
[ 1.109807] pci_bus 0000:03: resource 7 [mem 0x000c0000-0x000dffff]
[ 1.109808] pci_bus 0000:03: resource 8 [mem 0xfed40000-0xfed44fff]
[ 1.109809] pci_bus 0000:03: resource 9 [mem 0xe0000000-0xfebfffff]
[ 1.109811] pci_bus 0000:04: resource 0 [io 0xe000-0xefff]
[ 1.109812] pci_bus 0000:04: resource 1 [mem 0xfbb00000-0xfbbfffff]
[ 1.109813] pci_bus 0000:04: resource 4 [io 0xe000-0xefff]
[ 1.109814] pci_bus 0000:04: resource 5 [mem 0xfbb00000-0xfbbfffff]
[ 1.109815] pci_bus 0000:04: resource 8 [io 0x0000-0x0cf7]
[ 1.109816] pci_bus 0000:04: resource 9 [io 0x0d00-0xffff]
[ 1.109817] pci_bus 0000:04: resource 10 [mem 0x000a0000-0x000bffff]
[ 1.109819] pci_bus 0000:04: resource 11 [mem 0x000c0000-0x000dffff]
[ 1.109820] pci_bus 0000:04: resource 12 [mem 0xfed40000-0xfed44fff]
[ 1.109821] pci_bus 0000:04: resource 13 [mem 0xe0000000-0xfebfffff]
[ 1.109822] pci_bus 0000:05: resource 1 [mem 0xfba00000-0xfbafffff]
[ 1.109824] pci_bus 0000:06: resource 1 [mem 0xfbe00000-0xfbefffff]
[ 1.109825] pci_bus 0000:07: resource 0 [io 0xd000-0xdfff]
[ 1.109826] pci_bus 0000:07: resource 2 [mem 0xfbd00000-0xfbdfffff 64bit pref]
[ 1.109827] pci_bus 0000:08: resource 0 [io 0xc000-0xcfff]
[ 1.109828] pci_bus 0000:08: resource 1 [mem 0xfbc00000-0xfbcfffff]
[ 1.109830] pci_bus 0000:08: resource 2 [mem 0xf0000000-0xf00fffff pref]
[ 1.109842] NET: Registered protocol family 2
[ 1.109984] IP route cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 1.110591] TCP established hash table entries: 524288 (order: 11, 8388608 bytes)
[ 1.112272] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.112500] TCP: Hash tables configured (established 524288 bind 65536)
[ 1.112503] TCP reno registered
[ 1.112513] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 1.112551] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 1.112642] NET: Registered protocol family 1
[ 1.135851] pci 0000:01:00.0: Boot video device
[ 1.135961] PCI: CLS 4 bytes, default 64
[ 1.135994] Trying to unpack rootfs image as initramfs...
[ 1.476939] Freeing initrd memory: 30912k freed
[ 1.480375] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 1.480382] Placing 64MB software IO TLB between ffff8800db77a000 - ffff8800df77a000
[ 1.480385] software IO TLB at phys 0xdb77a000 - 0xdf77a000
[ 1.480843] microcode: CPU0 sig=0x206a7, pf=0x2, revision=0x14
[ 1.480849] microcode: CPU1 sig=0x206a7, pf=0x2, revision=0x14
[ 1.480855] microcode: CPU2 sig=0x206a7, pf=0x2, revision=0x14
[ 1.480862] microcode: CPU3 sig=0x206a7, pf=0x2, revision=0x14
[ 1.480868] microcode: CPU4 sig=0x206a7, pf=0x2, revision=0x14
[ 1.480875] microcode: CPU5 sig=0x206a7, pf=0x2, revision=0x14
[ 1.480880] microcode: CPU6 sig=0x206a7, pf=0x2, revision=0x14
[ 1.480885] microcode: CPU7 sig=0x206a7, pf=0x2, revision=0x14
[ 1.480897] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 1.480955] audit: initializing netlink socket (disabled)
[ 1.480962] type=2000 audit(1373404313.236:1): initialized
[ 1.490312] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 1.491517] VFS: Disk quotas dquot_6.5.2
[ 1.491548] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.491629] msgmni has been set to 15970
[ 1.491740] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 1.491755] io scheduler noop registered
[ 1.491757] io scheduler deadline registered
[ 1.491775] io scheduler cfq registered (default)
[ 1.491851] pcieport 0000:00:01.0: setting latency timer to 64
[ 1.491869] pcieport 0000:00:01.0: irq 40 for MSI/MSI-X
[ 1.492099] vesafb: mode is 800x600x16, linelength=1600, pages=2
[ 1.492101] vesafb: scrolling: redraw
[ 1.492103] vesafb: Truecolor: size=0:5:6:5, shift=0:11:5:0
[ 1.492283] vesafb: framebuffer at 0xef000000, mapped to 0xffffc90005800000, using 1875k, total 14336k
[ 1.501844] Console: switching to colour frame buffer device 100x37
[ 1.511223] fb0: VESA VGA frame buffer device
[ 1.511357] intel_idle: MWAIT substates: 0x1120
[ 1.511358] intel_idle: v0.4 model 0x2A
[ 1.511358] intel_idle: lapic_timer_reliable_states 0xffffffff
[ 1.511420] input: Power Button as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0
[ 1.511661] ACPI: Power Button [PWRB]
[ 1.511796] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 1.512012] ACPI: Power Button [PWRF]
[ 1.512132] ACPI: acpi_idle yielding to intel_idle
[ 1.513446] ERST: Table is not found!
[ 1.513588] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.538006] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.572372] 00:07: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.576687] Linux agpgart interface v0.103
[ 1.581444] brd: module loaded
[ 1.585772] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[ 1.590297] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 1.599419] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.603962] mousedev: PS/2 mouse device common for all mice
[ 1.608541] rtc_cmos 00:04: RTC can wake from S4
[ 1.613117] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0
[ 1.617633] rtc0: alarms up to one month, 242 bytes nvram, hpet irqs
[ 1.622228] cpuidle: using governor ladder
[ 1.626819] cpuidle: using governor menu
[ 1.631234] TCP cubic registered
[ 1.635429] Registering the dns_resolver key type
[ 1.635907] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input2
[ 1.644230] PM: Checking hibernation image partition UUID=ee03a220-9a49-4b91-aa1c-66f9f1bdb272
[ 1.644232] PM: Hibernation image not present or could not be loaded.
[ 1.644237] registered taskstats version 1
[ 1.649349] Magic number: 5:526:196
[ 1.653873] rtc_cmos 00:04: setting system clock to 2013-07-09 21:11:54 UTC (1373404314)
[ 1.658252] BIOS EDD facility v0.16 2004-Jun-25, 2 devices found
[ 1.663533] Freeing unused kernel memory: 772k freed
[ 1.668058] Write protecting the kernel read-only data: 8192k
[ 1.675775] Freeing unused kernel memory: 1856k freed
[ 1.680484] Freeing unused kernel memory: 48k freed
[ 1.697908] dracut: dracut-010-6
[ 1.712581] device-mapper: uevent: version 1.0.3
[ 1.716650] device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-devel@redhat.com
[ 1.722218] loop: module loaded
[ 1.732144] udevd[126]: starting version 168
[ 1.780986] dracut: Starting plymouth daemon
[ 2.120577] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 2.120599] r8169 0000:07:00.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 2.120658] r8169 0000:07:00.0: setting latency timer to 64
[ 2.120667] r8169 0000:07:00.0: (unregistered net_device): unknown MAC, using family default
[ 2.120757] r8169 0000:07:00.0: irq 41 for MSI/MSI-X
[ 2.120962] r8169 0000:07:00.0: eth0: RTL8168b/8111b at 0xffffc90000c74000, 50:e5:49:34:54:84, XID 0c900800 IRQ 41
[ 2.138226] SCSI subsystem initialized
[ 2.142291] firewire_ohci 0000:04:02.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 2.146123] usbcore: registered new interface driver usbfs
[ 2.146139] usbcore: registered new interface driver hub
[ 2.146185] usbcore: registered new device driver usb
[ 2.155138] libata version 3.00 loaded.
[ 2.157343] pata_acpi 0000:00:1f.2: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[ 2.157359] pata_acpi 0000:00:1f.2: setting latency timer to 64
[ 2.157367] pata_acpi 0000:00:1f.2: PCI INT B disabled
[ 2.157377] pata_acpi 0000:00:1f.5: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[ 2.157389] pata_acpi 0000:00:1f.5: setting latency timer to 64
[ 2.157403] pata_acpi 0000:00:1f.5: PCI INT B disabled
[ 2.157421] pata_acpi 0000:08:00.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[ 2.157435] pata_acpi 0000:08:00.0: setting latency timer to 64
[ 2.157443] pata_acpi 0000:08:00.0: PCI INT A disabled
[ 2.159476] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.159486] ehci_hcd 0000:00:1a.0: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 2.159522] ehci_hcd 0000:00:1a.0: setting latency timer to 64
[ 2.159524] ehci_hcd 0000:00:1a.0: EHCI Host Controller
[ 2.159535] ehci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 2.168943] ehci_hcd 0000:00:1a.0: debug port 2
[ 2.172823] ehci_hcd 0000:00:1a.0: cache line size of 4 is not supported
[ 2.172835] ehci_hcd 0000:00:1a.0: irq 18, io mem 0xfbffe000
[ 2.181880] ehci_hcd 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 2.181904] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.181908] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.181911] usb usb1: Product: EHCI Host Controller
[ 2.181913] usb usb1: Manufacturer: Linux 2.6.39.4-4.2-desktop ehci_hcd
[ 2.181915] usb usb1: SerialNumber: 0000:00:1a.0
[ 2.182018] hub 1-0:1.0: USB hub found
[ 2.182020] hub 1-0:1.0: 2 ports detected
[ 2.182067] ehci_hcd 0000:00:1d.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23
[ 2.182114] ehci_hcd 0000:00:1d.0: setting latency timer to 64
[ 2.182116] ehci_hcd 0000:00:1d.0: EHCI Host Controller
[ 2.182120] ehci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 2.186879] ehci_hcd 0000:00:1d.0: debug port 2
[ 2.190748] ehci_hcd 0000:00:1d.0: cache line size of 4 is not supported
[ 2.190757] ehci_hcd 0000:00:1d.0: irq 23, io mem 0xfbffd000
[ 2.192905] firewire_ohci: Added fw-ohci device 0000:04:02.0, OHCI v1.10, 4 IR + 8 IT contexts, quirks 0x11
[ 2.199824] ehci_hcd 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 2.199847] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.199851] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.199853] usb usb2: Product: EHCI Host Controller
[ 2.199855] usb usb2: Manufacturer: Linux 2.6.39.4-4.2-desktop ehci_hcd
[ 2.199858] usb usb2: SerialNumber: 0000:00:1d.0
[ 2.199954] hub 2-0:1.0: USB hub found
[ 2.199956] hub 2-0:1.0: 2 ports detected
[ 2.200044] ata_piix 0000:00:1f.2: version 2.13
[ 2.200051] ata_piix 0000:00:1f.2: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[ 2.200054] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 2.200086] ata_piix 0000:00:1f.2: setting latency timer to 64
[ 2.200384] scsi0 : ata_piix
[ 2.200475] scsi1 : ata_piix
[ 2.200730] ata1: SATA max UDMA/133 cmd 0xff00 ctl 0xfe00 bmdma 0xfb00 irq 19
[ 2.200734] ata2: SATA max UDMA/133 cmd 0xfd00 ctl 0xfc00 bmdma 0xfb08 irq 19
[ 2.200744] ata_piix 0000:00:1f.5: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[ 2.200748] ata_piix 0000:00:1f.5: MAP [ P0 -- P1 -- ]
[ 2.200795] ata_piix 0000:00:1f.5: setting latency timer to 64
[ 2.200947] scsi2 : ata_piix
[ 2.201023] scsi3 : ata_piix
[ 2.201263] ata3: SATA max UDMA/133 cmd 0xf800 ctl 0xf700 bmdma 0xf400 irq 19
[ 2.201266] ata4: SATA max UDMA/133 cmd 0xf600 ctl 0xf500 bmdma 0xf408 irq 19
[ 2.479025] Refined TSC clocksource calibration: 3392.293 MHz.
[ 2.479031] Switching to clocksource tsc
[ 2.483015] usb 1-1: new high speed USB device number 2 using ehci_hcd
[ 2.515779] ata3: SATA link down (SStatus 0 SControl 300)
[ 2.597103] usb 1-1: New USB device found, idVendor=8087, idProduct=0024
[ 2.597108] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.597338] hub 1-1:1.0: USB hub found
[ 2.597418] hub 1-1:1.0: 6 ports detected
[ 2.655555] ata4: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 2.658641] ata4.00: ATAPI: ATAPI iHAS124 B, AL0S, max UDMA/100
[ 2.664622] ata4.00: configured for UDMA/100
[ 2.692484] firewire_core: created device fw0: GUID 0049e550c58b0000, S400
[ 2.699397] usb 2-1: new high speed USB device number 2 using ehci_hcd
[ 2.813459] usb 2-1: New USB device found, idVendor=8087, idProduct=0024
[ 2.813464] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.813690] hub 2-1:1.0: USB hub found
[ 2.813796] hub 2-1:1.0: 8 ports detected
[ 2.959735] ata1.00: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 2.959749] ata1.01: SATA link down (SStatus 0 SControl 300)
[ 2.959918] ata2.00: SATA link down (SStatus 0 SControl 300)
[ 2.959928] ata2.01: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.971075] ata1.00: ATA-8: ST1000DM003-9YN162, CC46, max UDMA/133
[ 2.971081] ata1.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 2.973922] ata2.01: ATA-8: ST1000DM003-9YN162, CC46, max UDMA/133
[ 2.973927] ata2.01: 1953525168 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 2.976928] ata1.00: configured for UDMA/133
[ 2.977042] scsi 0:0:0:0: Direct-Access ATA ST1000DM003-9YN1 CC46 PQ: 0 ANSI: 5
[ 2.979907] ata2.01: configured for UDMA/133
[ 2.980063] scsi 1:0:1:0: Direct-Access ATA ST1000DM003-9YN1 CC46 PQ: 0 ANSI: 5
[ 2.983797] scsi 3:0:0:0: CD-ROM ATAPI iHAS124 B AL0S PQ: 0 ANSI: 5
[ 2.989519] sd 1:0:1:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB)
[ 2.989522] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB)
[ 2.989532] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 2.989542] sd 1:0:1:0: [sdb] 4096-byte physical blocks
[ 2.989579] sd 1:0:1:0: [sdb] Write Protect is off
[ 2.989581] sd 0:0:0:0: [sda] Write Protect is off
[ 2.989583] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.989585] sd 1:0:1:0: [sdb] Mode Sense: 00 3a 00 00
[ 2.989607] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.989610] sd 1:0:1:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.994078] sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
[ 2.994083] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 2.994179] sr 3:0:0:0: Attached scsi CD-ROM sr0
[ 3.004995] sda: sda1 sda2 sda3 < sda5 >
[ 3.005212] sd 0:0:0:0: [sda] Attached SCSI disk
[ 3.006221] sdb: sdb1 sdb2 < sdb5 sdb6 >
[ 3.006451] sd 1:0:1:0: [sdb] Attached SCSI disk
[ 4.313568] PM: Marking nosave pages: 000000000009f000 - 0000000000100000
[ 4.313570] PM: Marking nosave pages: 00000000df780000 - 0000000100000000
[ 4.313829] PM: Basic memory bitmaps created
[ 4.334215] PM: Basic memory bitmaps freed
[ 4.336646] PM: Starting manual resume from disk
[ 4.336649] PM: Hibernation image partition 8:22 present
[ 4.336649] PM: Looking for hibernation image.
[ 4.360989] PM: Image not found (code -22)
[ 4.360990] PM: Hibernation image not present or could not be loaded.
[ 4.422769] EXT3-fs: barriers not enabled
[ 4.435618] kjournald starting. Commit interval 5 seconds
[ 4.435654] EXT3-fs (sdb5): mounted filesystem with ordered data mode
[ 4.484126] dracut: Checking filesystems
[ 4.484139] dracut: fsck -T -t noopts=_netdev -A -a
[ 4.606160] dracut: /dev/sdb5: clean, 539446/6258688 files, 6357112/25005156 blocks
[ 4.606272] dracut: Remounting /dev/disk/by-uuid/7c33fa14-4939-4567-bdbb-808a54338cd5 with -o ro,acl,relatime
[ 4.636202] EXT3-fs: barriers not enabled
[ 4.636516] kjournald starting. Commit interval 5 seconds
[ 4.636600] EXT3-fs (sdb5): mounted filesystem with ordered data mode
[ 4.649121] dracut: Mounted root filesystem /dev/sdb5
[ 4.893884] dracut: Switching root
[ 4.920705] Not activating Mandatory Access Control now since /sbin/tomoyo-init doesn't exist.
[ 5.126766] systemd[1]: systemd 29 running in system mode. (+PAM +LIBWRAP +AUDIT -SELINUX +SYSVINIT +LIBCRYPTSETUP; mandriva)
[ 5.291030] NET: Registered protocol family 10
[ 5.304095] systemd[1]: Set hostname to <localhost.localdomain>.
[ 5.312083] systemd[1]: /etc/mtab is not a symlink or not pointing to /proc/self/mounts. This is not supported anymore. Please make sure to replace this file by a symlink to avoid incorrect or misleading mount(8) output.
[ 5.401800] systemd[1]: access() failed on /etc/rc.d/rc1.d/K00boinc-client: Permission denied
[ 5.403695] systemd[1]: access() failed on /etc/rc.d/rc2.d/K00boinc-client: Permission denied
[ 5.404385] systemd[1]: access() failed on /etc/rc.d/rc3.d/K00boinc-client: Permission denied
[ 5.405010] systemd[1]: access() failed on /etc/rc.d/rc4.d/K00boinc-client: Permission denied
[ 5.406281] systemd[1]: access() failed on /etc/rc.d/rc5.d/K00boinc-client: Permission denied
[ 5.407256] systemd[1]: access() failed on /etc/rc.d/rc0.d/K00boinc-client: Permission denied
[ 5.407988] systemd[1]: access() failed on /etc/rc.d/rc6.d/K00boinc-client: Permission denied
[ 5.607367] systemd[1]: [/etc/rc.d/init.d/iptables:18] Failed to add LSB Provides name firewall.service, ignoring: File exists
[ 6.330555] udevd[463]: starting version 168
[ 6.330614] /etc/rc.modules[475]: Loading modules: evdev acpi-cpufreq cpufreq_performance cpufreq_powersave cpufreq_conservative cpufreq_ondemand
[ 6.411852] EXT3-fs (sdb5): using internal journal
[ 6.721678] iTCO_vendor_support: vendor-support=0
[ 6.722652] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.06
[ 6.722729] iTCO_wdt: unable to reset NO_REBOOT flag, device disabled by hardware/BIOS
[ 6.800467] xhci_hcd 0000:05:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 6.800492] xhci_hcd 0000:05:00.0: setting latency timer to 64
[ 6.800495] xhci_hcd 0000:05:00.0: xHCI Host Controller
[ 6.800502] xhci_hcd 0000:05:00.0: new USB bus registered, assigned bus number 3
[ 6.810727] xhci_hcd 0000:05:00.0: irq 16, io mem 0xfbaf8000
[ 6.810746] xhci_hcd 0000:05:00.0: Failed to enable MSI-X
[ 6.810796] xhci_hcd 0000:05:00.0: irq 42 for MSI/MSI-X
[ 6.810849] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 6.810851] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.810852] usb usb3: Product: xHCI Host Controller
[ 6.810853] usb usb3: Manufacturer: Linux 2.6.39.4-4.2-desktop xhci_hcd
[ 6.810854] usb usb3: SerialNumber: 0000:05:00.0
[ 6.810903] xHCI xhci_add_endpoint called for root hub
[ 6.810904] xHCI xhci_check_bandwidth called for root hub
[ 6.810924] hub 3-0:1.0: USB hub found
[ 6.810931] hub 3-0:1.0: 2 ports detected
[ 6.810971] xhci_hcd 0000:05:00.0: xHCI Host Controller
[ 6.810974] xhci_hcd 0000:05:00.0: new USB bus registered, assigned bus number 4
[ 6.817593] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 6.817596] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.817598] usb usb4: Product: xHCI Host Controller
[ 6.817600] usb usb4: Manufacturer: Linux 2.6.39.4-4.2-desktop xhci_hcd
[ 6.817603] usb usb4: SerialNumber: 0000:05:00.0
[ 6.817675] xHCI xhci_add_endpoint called for root hub
[ 6.817678] xHCI xhci_check_bandwidth called for root hub
[ 6.817707] hub 4-0:1.0: USB hub found
[ 6.817714] hub 4-0:1.0: 2 ports detected
[ 6.817750] xhci_hcd 0000:06:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 6.817764] xhci_hcd 0000:06:00.0: setting latency timer to 64
[ 6.817766] xhci_hcd 0000:06:00.0: xHCI Host Controller
[ 6.817770] xhci_hcd 0000:06:00.0: new USB bus registered, assigned bus number 5
[ 6.826657] xhci_hcd 0000:06:00.0: irq 17, io mem 0xfbef8000
[ 6.826675] xhci_hcd 0000:06:00.0: Failed to enable MSI-X
[ 6.826728] xhci_hcd 0000:06:00.0: irq 43 for MSI/MSI-X
[ 6.826788] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 6.826790] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.826792] usb usb5: Product: xHCI Host Controller
[ 6.826794] usb usb5: Manufacturer: Linux 2.6.39.4-4.2-desktop xhci_hcd
[ 6.826795] usb usb5: SerialNumber: 0000:06:00.0
[ 6.826855] xHCI xhci_add_endpoint called for root hub
[ 6.826856] xHCI xhci_check_bandwidth called for root hub
[ 6.826876] hub 5-0:1.0: USB hub found
[ 6.826883] hub 5-0:1.0: 2 ports detected
[ 6.826931] xhci_hcd 0000:06:00.0: xHCI Host Controller
[ 6.826936] xhci_hcd 0000:06:00.0: new USB bus registered, assigned bus number 6
[ 6.832080] cfg80211: Calling CRDA to update world regulatory domain
[ 6.836532] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[ 6.836534] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.836535] usb usb6: Product: xHCI Host Controller
[ 6.836536] usb usb6: Manufacturer: Linux 2.6.39.4-4.2-desktop xhci_hcd
[ 6.836537] usb usb6: SerialNumber: 0000:06:00.0
[ 6.836577] xHCI xhci_add_endpoint called for root hub
[ 6.836579] xHCI xhci_check_bandwidth called for root hub
[ 6.836598] hub 6-0:1.0: USB hub found
[ 6.836604] hub 6-0:1.0: 2 ports detected
[ 6.951379] wmi: Mapper loaded
[ 7.096749] i801_smbus 0000:00:1f.3: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 7.127694] usb 5-1: new low speed USB device number 2 using xhci_hcd
[ 7.160814] xhci_hcd 0000:06:00.0: WARN: short transfer on control ep
[ 7.172775] xhci_hcd 0000:06:00.0: WARN: short transfer on control ep
[ 7.177734] xhci_hcd 0000:06:00.0: WARN: short transfer on control ep
[ 7.178786] usb 5-1: New USB device found, idVendor=045e, idProduct=00e1
[ 7.178789] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7.178792] usb 5-1: Product: Microsoft Wireless Optical Mouse® 1.00
[ 7.178794] usb 5-1: Manufacturer: Microsoft
[ 7.178860] usb 5-1: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 7.288834] HDA Intel 0000:00:1b.0: PCI INT A -> GSI 22 (level, low) -> IRQ 22
[ 7.288922] HDA Intel 0000:00:1b.0: irq 44 for MSI/MSI-X
[ 7.288948] HDA Intel 0000:00:1b.0: setting latency timer to 64
[ 7.305885] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 7.305900] sd 1:0:1:0: Attached scsi generic sg1 type 0
[ 7.305926] sr 3:0:0:0: Attached scsi generic sg2 type 5
[ 7.355607] hda_codec: ALC889: BIOS auto-probing.
[ 7.355609] SKU: Nid=0x1d sku_cfg=0x4005e601
[ 7.355610] SKU: port_connectivity=0x1
[ 7.355611] SKU: enable_pcbeep=0x0
[ 7.355612] SKU: check_sum=0x00000005
[ 7.355613] SKU: customization=0x000000e6
[ 7.355613] SKU: external_amp=0x0
[ 7.355614] SKU: platform_type=0x0
[ 7.355614] SKU: swap=0x0
[ 7.355615] SKU: override=0x1
[ 7.355618] autoconfig: line_outs=4 (0x14/0x15/0x16/0x17/0x0)
[ 7.355619] speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 7.355620] hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 7.355620] mono: mono_out=0x0
[ 7.355621] dig-out=0x11/0x1e
[ 7.355622] inputs:
[ 7.357085] realtek: No valid SSID, checking pincfg 0x4005e601 for NID 0x1d
[ 7.357086] realtek: Enabling init ASM_ID=0xe601 CODEC_ID=10ec0889
[ 7.363091] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input3
[ 7.363154] HDA Intel 0000:01:00.1: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[ 7.363156] hda_intel: Disable MSI for Nvidia chipset
[ 7.363214] HDA Intel 0000:01:00.1: setting latency timer to 64
[ 7.403505] mtp-probe[1224]: checking bus 5, device 2: "/sys/devices/pci0000:00/0000:00:1c.5/0000:06:00.0/usb5/5-1"
[ 7.404112] mtp-probe[1224]: bus: 5, device: 2 was not an MTP device
[ 7.666275] xhci_hcd 0000:06:00.0: WARN: Stalled endpoint
[ 7.706411] input: Microsoft Microsoft Wireless Optical Mouse® 1.00 as /devices/pci0000:00/0000:00:1c.5/0000:06:00.0/usb5/5-1/5-1:1.0/input/input4
[ 7.706481] generic-usb 0003:045E:00E1.0001: input,hidraw0: USB HID v1.11 Mouse [Microsoft Microsoft Wireless Optical Mouse® 1.00] on usb-0000:06:00.0-1/input0
[ 7.706492] usbcore: registered new interface driver usbhid
[ 7.706494] usbhid: USB HID core driver
[ 7.719441] ath9k 0000:04:00.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[ 9.286412] ath: EEPROM regdomain: 0x30
[ 9.286414] ath: EEPROM indicates we should expect a direct regpair map
[ 9.286415] ath: Country alpha2 being used: AM
[ 9.286416] ath: Regpair used: 0x30
[ 9.345464] ieee80211 phy0: Selected rate control algorithm 'ath9k_rate_control'
[ 9.345720] Registered led device: ath9k-phy0
[ 9.345723] ieee80211 phy0: Atheros AR9280 Rev:2 mem=0xffffc90005ac0000, irq=19
[ 9.816383] cfg80211: World regulatory domain updated:
[ 9.816384] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 9.816386] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 9.816387] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 9.816389] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 9.816390] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 9.816391] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 9.816396] cfg80211: Calling CRDA for country: AM
[ 9.819081] cfg80211: Regulatory domain changed to country: AM
[ 9.819082] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 9.819084] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 9.819085] cfg80211: (5170000 KHz - 5250000 KHz @ 20000 KHz), (N/A, 1800 mBm)
[ 9.819086] cfg80211: (5250000 KHz - 5330000 KHz @ 20000 KHz), (N/A, 1800 mBm)
[ 9.967677] Adding 21735908k swap on /dev/sdb6. Priority:0 extents:1 across:21735908k
[ 10.128593] nvidia: module license 'NVIDIA' taints kernel.
[ 10.128596] Disabling lock debugging due to kernel taint
[ 10.183372] fuse init (API version 7.16)
[ 10.428697] ntfs-3g[1435]: Version 2011.4.12 external FUSE 28
[ 10.428704] ntfs-3g[1435]: Mounted /dev/sda2 (Read-Write, label "", NTFS 3.1)
[ 10.428708] ntfs-3g[1435]: Cmdline options: rw,umask=000
[ 10.428713] ntfs-3g[1435]: Mount options: rw,allow_other,nonempty,atime,fsname=/dev/sda2,blkdev,blksize=4096,default_permissions
[ 10.428717] ntfs-3g[1435]: Global ownership and permissions enforced, configuration type 1
[ 10.454628] ntfs-3g[1438]: Version 2011.4.12 external FUSE 28
[ 10.454634] ntfs-3g[1438]: Mounted /dev/sda1 (Read-Write, label "Зарезервировано системой", NTFS 3.1)
[ 10.454646] ntfs-3g[1438]: Cmdline options: rw,umask=000
[ 10.454649] ntfs-3g[1438]: Mount options: rw,allow_other,nonempty,atime,fsname=/dev/sda1,blkdev,blksize=4096,default_permissions
[ 10.454653] ntfs-3g[1438]: Global ownership and permissions enforced, configuration type 1
[ 10.464310] nvidia 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 10.464315] nvidia 0000:01:00.0: setting latency timer to 64
[ 10.464319] vgaarb: device changed decodes: PCI:0000:01:00.0,olddecodes=io+mem,decodes=none:owns=io+mem
[ 10.464486] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 280.13 Wed Jul 27 16:53:56 PDT 2011
[ 10.523495] FAT: utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[ 10.595529] ntfs-3g[1455]: Version 2011.4.12 external FUSE 28
[ 10.595534] ntfs-3g[1455]: Mounted /dev/sda5 (Read-Write, label "WINDOWS DATA", NTFS 3.1)
[ 10.595538] ntfs-3g[1455]: Cmdline options: rw,umask=000
[ 10.595542] ntfs-3g[1455]: Mount options: rw,allow_other,nonempty,atime,fsname=/dev/sda5,blkdev,blksize=4096,default_permissions
[ 10.595546] ntfs-3g[1455]: Global ownership and permissions enforced, configuration type 1
[ 13.878208] service_harddrake[1695]: ### Program is starting ###
[ 14.204914] systemd-tmpfiles[1698]: [/usr/lib/tmpfiles.d/legacy.conf:22] Unknown group 'lock'.
[ 14.344609] systemd[1]: systemd-tmpfiles-setup.service: main process exited, code=exited, status=1
[ 14.363079] systemd[1]: Unit systemd-tmpfiles-setup.service entered failed state.
[ 14.564140] service_harddrake[1695]: running: dmidecode
[ 14.665419] service_harddrake[1695]: modified file /etc/sysconfig/harddrake2/kernel
[ 14.685038] service_harddrake[1695]: modified file /etc/sysconfig/harddrake2/xorg
[ 14.764021] service_harddrake[1695]: created file /etc/sysconfig/harddrake2/previous_hw
[ 14.765020] service_harddrake[1695]: launched command: display_driver_helper --check-loaded
[ 14.941693] vboxdrv: Found 8 processor cores.
[ 14.941741] VBoxDrv: dbg - g_abExecMemory=ffffffffa10b9220
[ 14.941937] vboxdrv: fAsync=0 offMin=0x1a4 offMax=0x17c40
[ 14.941969] vboxdrv: TSC mode is 'synchronous', kernel timer mode is 'normal'.
[ 14.941971] vboxdrv: Successfully loaded version 4.0.8_OSE (interface 0x00180000).
[ 15.526220] crond[1909]: (CRON) STARTUP (1.4.7)
[ 15.526346] crond[1909]: (CRON) INFO (Syslog will be used instead of sendmail.): Нет такого файла или каталога
[ 15.701102] auditd[1947]: Started dispatcher: /sbin/audispd pid: 1949
[ 15.723436] audispd[1949]: priority_boost_parser called with: 4
[ 15.723441] audispd[1949]: max_restarts_parser called with: 10
[ 15.723978] audispd[1949]: No plugins found, exiting
[ 15.803320] auditd[1947]: Init complete, auditd 2.1.2 listening for events (startup state enable)
[ 16.061723] su[1900]: pam_tcb(su-l:session): Session opened for root by (uid=0)
[ 16.068836] crond[1909]: (CRON) INFO (running with inotify support)
[ 16.143271] lircd-0.8.7[1894]: config file contains no valid remote control definition
[ 16.143481] lircd-0.8.7[2018]: lircd(default) ready, using /var/run/lirc/lircd
[ 17.190188] systemd[1]: lm_sensors.service: main process exited, code=exited, status=1
[ 17.210000] systemd[1]: Unit lm_sensors.service entered failed state.
[ 18.392679] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 18.452075] NET: Registered protocol family 17
[ 18.543674] cfg80211: Calling CRDA for country: RU
[ 18.546308] cfg80211: Regulatory domain changed to country: RU
[ 18.546309] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 18.546311] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 18.546312] cfg80211: (5735000 KHz - 5835000 KHz @ 20000 KHz), (N/A, 3000 mBm)
[ 18.590465] r8169 0000:07:00.0: eth0: link down
[ 18.590953] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 21.135208] wlan0: authenticate with 34:08:04:b7:ec:d4 (try 1)
[ 21.137328] wlan0: authenticated
[ 21.137349] wlan0: associate with 34:08:04:b7:ec:d4 (try 1)
[ 21.140053] wlan0: RX AssocResp from 34:08:04:b7:ec:d4 (capab=0xc31 status=0 aid=1)
[ 21.140058] wlan0: associated
[ 21.140586] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 21.140700] cfg80211: Calling CRDA for country: GB
[ 21.143590] cfg80211: Regulatory domain changed to country: GB
[ 21.143591] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 21.143593] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 21.143594] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 21.143595] cfg80211: (5250000 KHz - 5330000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 21.143602] cfg80211: (5490000 KHz - 5710000 KHz @ 40000 KHz), (N/A, 2700 mBm)
[ 22.757915] tun: Universal TUN/TAP device driver, 1.6
[ 22.757917] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 23.328680] RPC: Registered udp transport module.
[ 23.328682] RPC: Registered tcp transport module.
[ 23.328683] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 23.354211] FS-Cache: Loaded
[ 23.383984] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 23.463852] FS-Cache: Netfs 'nfs' registered for caching
[ 24.689246] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 24.867794] NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory
[ 24.877397] NFSD: starting 90-second grace period
[ 24.977390] Netfilter messages via NETLINK v0.30.
[ 25.103719] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 30.425126] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 30.443671] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 30.443672] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 31.870932] wlan0: no IPv6 routers present
[ 32.715065] ctnetlink v0.93: registering with nfnetlink.
[ 37.434202] ip_set: protocol 6
[ 37.600191] u32 classifier
[ 37.600193] Actions configured
[ 37.765907] ipt_CLUSTERIP: ClusterIP Version 0.8 loaded successfully
[ 541.985527] ata1.00: configured for UDMA/133
[ 541.985530] ata1: EH complete
[ 542.250752] ata2.01: configured for UDMA/133
[ 542.250757] ata2: EH complete
[ 558.864569] warning: `VirtualBox' uses 32-bit capabilities (legacy support in use)
[ 560.267200] hda-intel: IRQ timing workaround is activated for card #1. Suggest a bigger bdl_pos_adj.
[ 1108.844996] operapluginwrap[31631]: segfault at 96000000aa ip 00007fbba984b370 sp 00007fff6b793ef0 error 4 in libgobject-2.0.so.0.2800.8[7fbba9818000+4d000][/spoiler]
